thaw all layers ...routine help
hello dear:
i am trying to use this routine to unfreeze all layers,
I have tried several methods and they have not worked.
I attach the file that I use.
any comment is welcomed
thanks
test.lsp test.DWG
There is already a default command for that "LAYTHW"
  • Thanks 1
I didn't know that - learn something every day!
  • Thanks 1
the command "LAYTHW"
applies to the red arrow only
but even side is still frozen
and it is what I want to defrost
This is viewport freeze. so its not the layer that is frozen its the viewport not showing the layer.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/vp-freeze-thaw-in-all-viewports-in-all-drawings/m-p/10556247/highlight/true#M418998
--Edit
if you only want to do specific layers change the "*" to layer names you want to freeze/thaw
"0,Defpoints,layer1"
Edited by mhupp
  • Thanks 1
I reckon that this is all I need for an internet search...... "autocad lisp thaw viewport layers"
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-file-to-thaw-all-layers-frozen-in-the-viewport/td-p/3797286
Ha, look at that 2nd result on the page.....
Though MHUPPS link also shows freezing them too
Edited by Steven P
  • Thanks 1
ACCOMPLISHED
THANKS
You have to skip the current layer except for ON or OFF, I believe.  Off will prompt for permission to OFF the current layer.
You can do the same in the layer dialog.  select first layer, shift select last layer, click the snowflake or lightbulb, whatever for the last layer.
You can also select all layers in the Layer Properties Manager then right-click and select "VP Thaw All Layers in All Viewports".
