LISP Code for Rectangle With Radiused Corners
I'm looking for a method using VLISP to draw a rectangle with radiused corners, all for of them. I can do a standard rectangle no problem but we have a need to have the corners radiused. Picking the location with GETPOINT is also no trouble. If I recall there is a way to do this using VLISP. The code will contain a few variables for the height and width and the location. But how does one get the corners to radius. Or would drawings a polyline be a better method?
Okay, a little testing and I think I have it. Will report back once I'm at a computer where one can do LISP coding without interference.
Edited by Bill Tillman
  1. Rectangle p1 p2
  2. ask for fillet radius
  3. fillet command with polyline option
  4. profit ??
  • Like 2
The RECTANG command is already have fillet option within so you need to specify it only once then draw the rectangle required.
  • Like 5
Command: RECTANG
Specify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]: f
Specify fillet radius for rectangles <10.0000>:
Specify other corner point or [Area/Dimensions/Rotation]:
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq ans (AH:getvalsm (list "Enter values " "Length " 5 4 "20" "Height " 5 4 "5" "Radius " 5 4 "2" )))
(setq len (atof (car ans)) ht (atof (cadr ans)) rad (atof (caddr ans)))
Bill pretty sure you have a copy of multi getvals.lsp
