Xerox AltaLink C8135 Keeps Asking for Resources
When I print to the above printer from model space all works well. But when I try from Layout tabs the printer says it's looking for punched hole paper. I've scoured over the settings and searched ad nauseum but it's still no go.
This machine is running Windows 11 with AutoCAD 2023 and I'm using the latest driver from Xerox for the printer.
Just to eliminate the obvious, you have checked the Plotter Configuration Editor with all of its device settings, right? And the Custom Properties on that same device tab? That's the first place I'd look if a wacky paper type came up.
You may need to go into windows printers and check all the settings I know with a old HP plotter needed to set up in Windows not CAD for particular task something like auto rotate.
