samifox Posted January 18, 2023 Posted January 18, 2023 hi does anyone know the font name AutoCAD uses for its interface? Quote
CyberAngel Posted January 18, 2023 Posted January 18, 2023 I believe the interface is defined in the operating system, in other words, you have to access the Registry to change it or even find out what the settings are. That's above my pay grade. Quote
tombu Posted January 19, 2023 Posted January 19, 2023 Many years ago you could modify the fonts used in the interface but AutoCAD has leaned towards leaning on Windows settings. This may help https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-change-text-size-on-the-ribbon-and-toolbars-in-AutoCAD.html Quote
Dana W Posted January 20, 2023 Posted January 20, 2023 Here's what use. I think the default is Consolus. 1 Quote
samifox Posted January 22, 2023 Author Posted January 22, 2023 On 1/20/2023 at 7:59 PM, Dana W said: Here's what use. I think the default is Consolus. hi is it a command line font only? is it the same font used for the interface? Thanks Shay Quote
Dana W Posted January 23, 2023 Posted January 23, 2023 (edited) You are right. That is only for the command line. I forgot that it has been a minute since one could change the window header and ribbon font. I should have hit Tombu's link first. They normally know what they are talking about. The OPTIONS/DISPLAY tab is only for the command line. I don't see a way to even identify window font even in windows settings. Edited January 23, 2023 by Dana W Quote
BIGAL Posted January 24, 2023 Posted January 24, 2023 (edited) There is some settings in the registery and they hold info like this. You have to be careful though changing registry values, its buried in software Autodesk or Bricsys. I know I changed some colors like the light / dark theme. Will try to find. Edited January 24, 2023 by BIGAL Quote
