land Posted January 15, 2023 Share Posted January 15, 2023 i need a lisp to select all entties automaticly in all circles. Quote Link to comment Share on other sites More sharing options...
Steven P Posted January 15, 2023 Share Posted January 15, 2023 I might be wrong but you can't use a selection set to select everything in a circle but you can select everything in a polyline. So you might select all circles as a select set something like (ssget "_X" '((0 . "CIRCLE"))) , then in each one draw a temporary polyline shape that touches the circle in lots of places... and use them as the selection set filter (ssget :cp I think - see Lee Mac ssget function reference for which to use). i think out there there in the internet there is a function to draw a temporary line inside a circle, but it is Sunday, CAD is of here, so I can't check for you) 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted January 15, 2023 Share Posted January 15, 2023 Simple way would be bounding box of circle. this creates points around circle. http://www.lee-mac.com/entitytopointlist.html 2 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 16, 2023 Share Posted January 16, 2023 Not a problem like Steven P make polygons that match cirlcle, then you get vertices and use that with (SSget "F" list) (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))) Quote Link to comment Share on other sites More sharing options...
