i need a lisp to select all entties automaticly in all circles.
I might be wrong but you can't use a selection set to select everything in a circle but you can select everything in a polyline. So you might select all circles as a  select set something like (ssget "_X" '((0 . "CIRCLE"))) , then in each one draw a temporary polyline shape that touches the circle in lots of places... and use them as the selection set filter (ssget :cp I think - see Lee Mac ssget function reference for which to use).
i think out there there in the internet there is a function to draw a temporary line inside a circle, but it is Sunday, CAD is of here, so I can't check for you)
  • Agree 1
Not a problem like Steven P make polygons that match cirlcle, then you get vertices and use that with (SSget "F" list)
(setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))
