Multileader without fields - Lee Mac Block Attributes To Multileader edit
Hello,
is there any chance to remove field reference with Lee Mac lisp for Block Attributes to multileader? Now multileader makes fields and I need just simple text. I attached full lisp and text DWG. I will appreciate for help with LISP.
Marcin
                        (vla-put-textstring mld
                            (strcat
                                (if (= "" (vla-get-textstring at1))
                                    (strcat
                                        "%<\\AcObjProp Object(%<\\_ObjId "
                                        (LM:ObjectID at1)
                                        ">%).TextString>%"
                                        (if (= "" (vla-get-textstring at2)) "" (chr 10))
                                    (strcat
                                        (LM:ObjectID at2)
                                        ">%).TextString>%"
BlockAttributesToMultileader-test.dwgFetching info... BlockAttributesToMultileader.lspFetching info...
Sunday so CAD is off here.... not checked my answer but if you comment out for example:
(LM:ObjectID at1)
">%).TextString>%"
(comment out rather than delete in case that doesn't work and you need to go back again)
and  replace with
TextString
and for the second case, if doesn't have the (if statement at the end of course
Hello Steven,
thank You for post. I've checked it but unfortunately it returns multileader without content. Console says "error: bad argument type: stringp nil".
Ah, it might be (vla-get-textstring at1) that you need to use (and (vla-get-textstring at2) instead of TextString
Edited by Steven P
Hi Steven,
Thank You very much it worked :)
