dimension value in autocad reverse rotation
mdchuyen
Drawing1.dwg
Hello friends
I have a drawing where the dimension values are currently being reversed. Do you guys have any solution to handle my attached drawing. Hope the helping
@SLW210 This isn't really a lisp issue its more of a interface one.
They were made when facing the wrong way (Bottom view I think). So their 210 looks like (210 0.0 0.0 -1.0)
This will mirror them around but the right way but also wont 100% fix the issue. because some will have to be adjusted.
;; Flips Backwards ploylines
(defun C:SWAP (/ SS)
  (if (setq SS (ssget "_X" '((210 0.0 0.0 -1.0))))
      (vl-cmdf "_.Mirror3d" SS "" "xy" "0,0,0" "y")
      (prompt (strcat "\nEntities Swapped: " (itoa (sslength SS))))
    (prompt "\nNothing to Swap!")
thank you very much. It helps me a lot
This is what it is, isn't it?
  • Agree 1
Yes, whomever was in that view when the dimension where made or they got flipped somehow. making them upside down when viewed from top
