Help - Window Selection 3D Autocad
Hi all,  the below command will prompt to Left Click a single Pipe. Is it possible to change it to use Window Selection instead of Left Click Selection?
(defun C:CurSP ()
    (command "_.comp2sizespec")
I've tried this but doesn't work:
(vl-load-com)
(defun C:CurSP(/ ss)
  (if (setq ss (ssget))
    (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "-comp2sizespec")
Edited by barristann
is this a command or custome lisp? only thing i find is acommand for cadworx.
Hi mhupp, it's a "CADWorx Plant I" command. I'm not sure if it's custom or not. This is how it looksimage.png.32350e5c4c51123bf0fc823e86b61bac.pngimage.png.c9935ffe55242214261914d8d55b3b45.png
If the command itself is only allowing you to pick one entity at a time. Than the only option might be to make a window selection but then feed them one at a time to the command. see if this works.
(defun C:CurSP (/ size ss)
  (setq size (getstring "\nSize: "))
    (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
      (command "_.comp2sizespec" ent "" size)
    (command "_.comp2sizespec" ss "") ; see if all at onece works
Edited by mhupp
I'll try this at work. Thank you mhupp.
Hi mhupp. I tried
I will only select 1 entity while using the Selection Window. So, I've also tried
(defun C:CurSP (/ ss)
setq ss (ssget)
(command "_.comp2sizespec" ss)
Thank you for helping mhupp. I think I have no choice but to click on the entity (instead of using a window to select the entity)
Did you try the first lisp? it will still allow you to select multiple but then only run the command and select one at a time.
I tried the first lisp too but didn't work unfortunately. I was hoping to replace the clicking with a window but I guess the command will not allow it. It's okay, I'll learn to live with it. Thank you again mhupp.
life's mantra unfortunately.
