land Posted January 10, 2023 Share Posted January 10, 2023 hello i have many circle and i must trim inside them i need a lisp to do that quickly with lisp Quote Link to comment Share on other sites More sharing options...
ronjonp Posted January 10, 2023 Share Posted January 10, 2023 8 hours ago, land said: hello i have many circle and i must trim inside them i need a lisp to do that quickly with lisp If it's for graphics, make that circle a block and create a mask with a hatch that is color 255,255,255. 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted January 10, 2023 Share Posted January 10, 2023 Would this be a good starting point? It trims a single polyline however could be modified I think for many objects inside a circle 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted January 10, 2023 Share Posted January 10, 2023 Made this a couple of weeks ago. https://www.cadtutor.net/forum/topic/76515-trim-inside-selected-rectangles/ should also work with circles. Quote Link to comment Share on other sites More sharing options...
land Posted January 14, 2023 Author Share Posted January 14, 2023 thank you thast from you and work good Quote (defun C:CC (/ coords ent rad e t1) (defun MTR (e t1 p / l c) (command "TRIM" e "") (command (list t1 p)) (command "") ) (setq rad (getreal"\nEnter radius: ")) (while (setq ent (car (entsel "\nSelect polyline (or press Enter to Exit) >> "))) (setq t1 ent) (setq coords (vl-remove-if 'not (mapcar (function (lambda(p) (if (= 10 (car p))(cdr p)) )) (entget ent) ) ; end mapcar )) ; end setq, vl-remove-if (setq coords (reverse coords)) (foreach pt coords (command "_circle" "_non" pt rad) (setq e nil) (setq e (entlast)) (setq p (assoc 10 (entget e))) (setq p (list (cadr p) (caddr p) (cadddr p))) (command "TRIM" e "") (command (list t1 p)) (command "") ) ; end foreach ) ; end while (princ) ) Quote Link to comment Share on other sites More sharing options...
