explode command does not work with selection window... help
leonucadomi
hi:
I use autocad 2013
explode command doesn't work with selection window from lsp.
just using the icon.
Does anyone know why and how to fix it?
thanks
locked layers?
nested blocks?
ssget might filter out what your trying to explode.
kinda hard to tell with out any code.
2 ways :
(setvar 'qaflags 1)
(vl-cmdf "_.explode" ss)
(setvar 'qaflags 0)
But working with QAFLAGS is little risky - if not reset to 0, CAD behaves strange...
(initcommandversion)
But this is somewhat not always good if (initcommandversion) function not available...
Edited by marko_ribar
  • Thanks 1
I just have it here in the file pgp....
I use the letter ñ
It runs but it doesn't let me select in the window
If I click on the icon, it allows selecting in the window
I'm with MHUPP here, tricky to work out the problem if we can't see the problem. Assuming it is a LISP rather than a shortcut key, somewhere will be a file containing the LISP... if you can find that then maybe - I know it is tricky - but maybe you could share the LISP and that will give us an idea. I guess this is a new thing and that before the LISP was working OK?
Another thing you could do is search the internet, there are lots of explode LISPs out there, for example:
Find one that works for you and replace what you are using now
;;https://www.cadtutor.net/forum/topic/17919-explode-in-autolisp/
(if (setq i -1 ss (ssget))
   (while (setq ent (ssname ss (setq i (1+ i))))
     (and (vlax-method-applicable-p
            (setq obj (vlax-ename->vla-object ent)) 'Explode)
            (vla-explode obj)
     (entdel ent)))
;;OR
;;https://forums.autodesk.com/t5/autocad-forum/explode-lisp/td-p/1181092
(setq ss (ssget))
(setq cnt 0)
(repeat (sslength ss)
  (command ".explode" (ssname ss cnt))
  (setq cnt (1+ cnt))
