I often import PDFs and scale using a fraction, such as "8/0.1234567".
But this won't work and I have to use "80000000/1234567".
Is there a setting that would allow the first method.
  • 3 weeks later...
No, you can use a fraction or decimal not both.
There's a rational numbering system and a decimal numbering system, the one you want doesn't exist.
You could enter 'CAL at the command line then enter 8/0.1234567 to get 64.8000473 returned.
  • Thanks 1
  • 1 month later...
Or you could use lisp function at commandline when input scale ratio : (/ 8 0.1234567)
  • Like 2
OK, is there a lisp function available?
Similar to using 'CAL just enter what ketxu posted for the scale at the command line. I doubt either would work in a dialog box.
That's a very odd scale though.
when you use scale, going through the options it will ask for a scale - where you'd normally type '80000000/1234567'
You can use this instead
( / 8 0.123456789)
which is the LISP code for 8 / 0123456789 - as above
scale
-Select Object
-Select Base Point
( / 8 0.123456789)
Thanks for clarifying tombu, Steven P, and also for the code ketxu.
