need help - Failed to set vpoint in 3d model space
Hi.
I'm trying to set the view point to "TOP-FRONT-RIGHT" with this line of code in my lisp:
(command-s "-vpoint" "1, 0, -1");;change view point to "TOP-FRONT-RIGHT"
but I'm getting this massege:
: (command-s "-vpoint" "1, 0, -1")
: -vpoint
Set view point or [Rotate/PLan view/PErspective] <0, 0, 1>:1, 0, -1nil
what am i doing wrong?...
thanks,
aridzv.
Edited by aridzv
This feeds it a list rather then a string.
(command-s "-vpoint" '(1  0 -1))
@mhupp
thanks.
I've tried it (actually I've tried it before posting this qution..) and getting the same error:
: (command-s "-vpoint" '(1  0 -1))
: -vpoint
Set view point or [Rotate/PLan view/PErspective] <0, 0, 1>:nil
why is that?...
*Post removed* .. bad suggestion. 🤪
Edited by ronjonp
  • Funny 1
whats the error? not changing it or are you lookin at the nil?  because It's changing it on this end. the nil is just being output because its lacking a (princ)
(defun C:test ()
Edited by mhupp
strangly it dosen't want to work...
1. here is the full lisp tht I'm using:
(defun c:chtmd ()
(command "workspace" "C" "Mechanical")
(command "-VISUALSTYLES" "_c" "o" "Modeling") ;; change visual style to modeling
(command-s "-vpoint" '(1 -1 1)) ;; CHANGE VIEWPORT TO "TOP-FRONT-RIGHT"
(SETVAR "UCSDETECT" 3)
(SETVAR "QUADDISPLAY" 5)
second, see the attached screenshot:
the lisp change the work space to Mechanical  and the VISUALSTYLE to modeling,
but fail to change the viewpoint...
aridzv
good one....👏😆
And on a slightly more serious note:
I move a lot between workspaces, and in each transition I need to perform three main actions:
1. changing the workspace.
2. changing the Visual style.
3. changing the point of view.
and on top of that also to change two variables.
A total of 5 actions.
The intention is to save those five actions and reduce them to one mouse click.
aridzv
Edited by aridzv
Simple answer remove the spaces in your xyz then it will work.
(command "-vpoint" "1,0,-1")
that was my firs try....
nop,it dosen't...🙄
O.K.
Got it...
It is necessary to load a saved view.
1. set the required view by using the "LOOKFROM" widget on the top-right corner of the screen or in any other way.
2. use the "VIEW" command  to open the drawing explorer in the "VIEWS" tab.
3. create a new view and copy it's name (I saved it as "TOP-FRONT-RIGHT").
4. the command to use it in:
(command-s "-v" "Restore" "TOP-FRONT-RIGHT") ;; CHANGE VIEWPOINT TO "TOP-FRONT-RIGHT"
(command "zoom" "e");; zomm to extened just to be sure that all the drawing is shown
Edited by aridzv
View is reset and worked properly as suggested. A bit of code from a program written like 20 years ago.
(if (= look "R")(command-s "-vpoint" "1,0,0"))
(if (= look "L")(command-s "-vpoint" "-1,0,0"))
(if (= look "F")(command-s "-vpoint" "0,-1,0"))
(if (= look "B")(command-s "-vpoint" "0,1,0"))
(if (= look "P")(command-s "-vpoint" "0,0,1"))
@BIGAL
Since you and  @mhupp insist that it should work I suspect it is a bug and I'll send a support request to bricscad team.
Thanks any way.
aridzv.
I only checked it on V22 and V23.
nevertheless, I submitted a support request to bricscad team.
the problem solved by bricscad support team.
apperntaly my user profile was currpted in some way (maybe to much lisp experimants... 😆).
I've re-load the default user profile and the command is working.
Edited by aridzv
