Aftertouch Posted January 4, 2023 Posted January 4, 2023 Hello all, I am looking for a way to make a 'default' way to create Etransmits for our company. I am running in a few problems here... Is seems like i cannot change the 'transmittal setup' trough Lisp, is that correct? So... i was thinking to create a new 'Transmittal setup' and share this with my co-workers. but i cannot seem to be able to import/export a etransmittal setup? Is there no way to do this? Quote
ronjonp Posted January 4, 2023 Posted January 4, 2023 Etransmit settings are stored in the registry: Quote Computer\HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R24.2\ACAD-6101:409\ETransmit\Setups\BIND Assuming you're all on the same version of CAD you could export these keys and import. ( Untested ) You could also look at all the subkeys and their values and possibly write them using lisp: 2 1 Quote
Aftertouch Posted January 5, 2023 Author Posted January 5, 2023 Alright, seems like thats the only way. Nailed it: Works like a charm. Thanks for the direction. (setq regeditetransmit (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Etransmit\\setups\\COMPANY SETUP")) (vl-registry-write regeditetransmit) (vl-registry-write regeditetransmit "AEC_EXPLODE_DWG" 0) (vl-registry-write regeditetransmit "AEC_TEMP_SETUP" 0) (vl-registry-write regeditetransmit "BindType" 0) (vl-registry-write regeditetransmit "BindXref" 0) (vl-registry-write regeditetransmit "Description" "") (vl-registry-write regeditetransmit "DestFile" "") (vl-registry-write regeditetransmit "DestFileAction" 0) (vl-registry-write regeditetransmit "DestFolder" "") (vl-registry-write regeditetransmit "FilePathOption" 0) (vl-registry-write regeditetransmit "IncludeDataLinkFile" 1) (vl-registry-write regeditetransmit "IncludeFont" 1) (vl-registry-write regeditetransmit "IncludeMaterialTextures" 1) (vl-registry-write regeditetransmit "IncludePhotometricWebFile" 1) (vl-registry-write regeditetransmit "IncludeSSFiles" 1) (vl-registry-write regeditetransmit "IncludeUnloadedReferences" 0) (vl-registry-write regeditetransmit "Name" "COMPANY SETUP") (vl-registry-write regeditetransmit "PackageType" 0) (vl-registry-write regeditetransmit "PurgeDatabase" 0) (vl-registry-write regeditetransmit "RootFolder" "") (vl-registry-write regeditetransmit "SaveDrawingFormat" 6) (vl-registry-write regeditetransmit "SendMail" 0) (vl-registry-write regeditetransmit "SetPlotterNone" 0) (vl-registry-write regeditetransmit "ShowInFolder" 0) (vl-registry-write regeditetransmit "UsePassword" 0) (vl-registry-write regeditetransmit "VisualFidelity" 1) 1 Quote
ronjonp Posted January 5, 2023 Posted January 5, 2023 @Aftertouch Glad you got it working FWIW I'd refactor the code like so: (vl-registry-write (setq regeditetransmit (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Etransmit\\setups\\COMPANY SETUP" ) ) ) (foreach pair '(("AEC_EXPLODE_DWG" 0) ("AEC_TEMP_SETUP" 0) ("BindType" 0) ("BindXref" 0) ("Description" "") ("DestFile" "") ("DestFileAction" 0) ("DestFolder" "") ("FilePathOption" 0) ("IncludeDataLinkFile" 1) ("IncludeFont" 1) ("IncludeMaterialTextures" 1) ("IncludePhotometricWebFile" 1) ("IncludeSSFiles" 1) ("IncludeUnloadedReferences" 0) ("Name" "COMPANY SETUP") ("PackageType" 0) ("PurgeDatabase" 0) ("RootFolder" "") ("SaveDrawingFormat" 6) ("SendMail" 0) ("SetPlotterNone" 0) ("ShowInFolder" 0) ("UsePassword" 0) ("VisualFidelity" 1) ) (vl-registry-write regeditetransmit (car pair) (cadr pair)) ) 2 Quote
