leonucadomi Posted December 28, 2022 Share Posted December 28, 2022 hello: any routine to load linetypes from lisp? thanks Quote Link to comment Share on other sites More sharing options...
Tsuky Posted December 28, 2022 Share Posted December 28, 2022 A complex example Creates a shp file of the shape for a complex linetype Compile this file Creates the linetype .lin model Makes the linetype table Load this type of line into the current drawing Linetype is available in the drawing ((lambda ( / f_shp f_lin doc) (if (not (findfile "rond_plein.shp")) (progn (setq f_shp (open (strcat (getvar "ROAMABLEROOTPREFIX") "support\\rond_plein.shp") "w")) (write-line "*128,66,RONDPLEIN" f_shp) (write-line "2,3,10,010,1,10,(1,000),2,010,1,10,(2,000),2,010,1,10,(3,000),2,010,1,10," f_shp) (write-line "(4,000),2,010,1,10,(5,000),2,010,1,10,(6,000),2,010,1,10,(7,000),2,010,1,10," f_shp) (write-line "(8,000),2,010,1,10,(9,000),2,010,1,10,(10,000),2,3,10,0" f_shp) (close f_shp) ) ) (command "_.compile" (strcat (getvar "ROAMABLEROOTPREFIX") "support\\rond_plein.shp")) (if (not (tblsearch "STYLE" "")) (entmakex '( (0 . "STYLE") (100 . "AcDbSymbolTableRecord") (100 . "AcDbTextStyleTableRecord") (2 . "") (70 . 1) (40 . 0.0) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 2.5) (3 . "rond_plein.shx") (4 . "") ) ) ) (entmake (list '(0 . "LTYPE") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLinetypeTableRecord") '(2 . "DotsLine") '(70 . 0) '(3 . "pointillé shx . . . .") '(72 . 65) '(73 . 2) '(40 . 1.0) '(49 . 1.0) '(74 . 4) '(75 . 128) (CONS 340 (TBLOBJNAME "STYLE" "")) '(46 . 0.1) '(50 . 0.0) '(44 . 0.0) '(45 . 0.0) '(49 . 0.0) '(74 . 0) ) ) (if (not (findfile "DotsLine.lin")) (progn (setq f_lin (open (strcat (getvar "ROAMABLEROOTPREFIX") "support\\DotsLine.lin") "w")) (write-line "*DotsLine,cloture shx . . . ." f_lin) (write-line "A,1,[RONDPLEIN,rond_plein.shx,x=0,s=.1],0" f_lin) (close f_lin) ) ) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (if (and (not (vlax-for item (vla-get-linetypes doc) (if (= (strcase (vla-get-name item)) (strcase "DotsLine")) T) ) ) (vl-catch-all-error-p (vl-catch-all-apply 'vla-load (list (vla-get-Linetypes doc) "DotsLine" "DotsLine.lin") ) ) ) nil T ) (princ "\nCréation de Type de Ligne \"DotsLine\" effectué!") (prin1) )) 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 28, 2022 Share Posted December 28, 2022 maybe this ; By alanh (defun loadLinetype (doc LineTypeName FileName) (if (and (not (existLinetype doc LineTypeName)) (vl-catch-all-error-p (vl-catch-all-apply 'vla-load (list (vla-get-Linetypes doc) LineTypeName FileName ) ) ) ) nil T ) ) (defun existLinetype (doc LineTypeName / item loaded) (vlax-for item (vla-get-linetypes doc) (if (= (strcase (vla-get-name item)) (strcase LineTypeName)) (setq loaded T) ) ) ) ;load missing linetypes ;;; returns: T if loaded else nil (loadLinetype doc "Fence" "custom.lin") (loadLinetype doc "Tree" "custom.lin") (loadLinetype doc "Water_main" "custom.lin") (loadLinetype doc "Gas_main" "custom.lin") (loadLinetype doc "Sewer_main" "custom.lin") Quote Link to comment Share on other sites More sharing options...
aridzv Posted December 29, 2022 Share Posted December 29, 2022 (edited) @leonucadomi Hi. I've attached 2 files: llt_Autocad.lsp for autocad lt_Bricscad.lsp for bricscad see if it helps... aridzv llt_Bricscad.lsp llt_Autocad.lsp Edited December 29, 2022 by aridzv 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 29, 2022 Share Posted December 29, 2022 2 hours ago, aridzv said: @leonucadomi Hi. I've attached 2 files: llt_Autocad.lsp for autocad lt_Bricscad.lsp for bricscad see if it helps... aridzv llt_Bricscad.lsp 241 B · 0 downloads llt_Autocad.lsp 245 B · 1 download I might be tempted to combine these to a single -capture everything- LISP using something like (if (findfile "ISO..lin") (setq linefile "Iso.lin") (setq linefile "acadiso.lin") ) fewer files to manage. 1 1 Quote Link to comment Share on other sites More sharing options...
aridzv Posted December 29, 2022 Share Posted December 29, 2022 (edited) 1 hour ago, Steven P said: I might be tempted to combine these to a single -capture everything- LISP using something like (if (findfile "ISO..lin") (setq linefile "Iso.lin") (setq linefile "acadiso.lin") ) fewer files to manage. True,I agree. but usually people either work with one or the other, and only rarely do they work simultaneously with both. Edited December 29, 2022 by aridzv 1 Quote Link to comment Share on other sites More sharing options...
aridzv Posted December 29, 2022 Share Posted December 29, 2022 @Steven P can you help me with a way to run this lisp on startup (not load - that is obvious...)? I've searched for S::STARTUP but could'nt find a way... Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 29, 2022 Share Posted December 29, 2022 Perhaps edit or make acaddoc.lsp file, which is a LISP file, loaded at each drawing - it is associated with the s:startup stuff too. The internet will help here? If this file exists it is loaded automatically. You could save your load linetype LISP in a trusted location folder and in the acaddoc.lsp file include the line / command (loadlinetype) - or whatever your LISP routine is Or if you want to save the file somewhere else, use something like also in the acaddoc.lsp file: (load "C:\\Users\\MyFilePAth\\loadlines.lsp" "loadlines Failed to Load") ;;Using full path with double '\' and the file name of your LISP file and then as above (loadlinetype) command. That should do it. I tend to put my LISPs in the startup suit but if you reload a LISP file anything in there that runs automatically will run again (for example, I have one that sets the snaps as I like, but if I change them while drawings and reload that LISP the snaps go to my default as an example why this approach doesn't work for everything). Quote Link to comment Share on other sites More sharing options...
aridzv Posted December 29, 2022 Share Posted December 29, 2022 (edited) @Steven P thanks for the reply. you gave me a few directions... what I did eventualy is this: I've made sure that the path to the LSP files folder is in the search path. in bricscad there are 2 types startup files - ON_DOC_LOAD.LSP that load for every time a new drawing is opened. ON_START.LSP that open only once when the software is starting. I've entered those lines of code to the ON_START.LSP file: (load "llt") (command "llt") and thats it... Edited December 29, 2022 by aridzv 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 29, 2022 Share Posted December 29, 2022 Ahh, Bricscad, we use AutoCAD so I didn't know the file names..... thanks, I learn something every day too!!! 1 Quote Link to comment Share on other sites More sharing options...
aridzv Posted December 29, 2022 Share Posted December 29, 2022 (edited) 37 minutes ago, Steven P said: Ahh, Bricscad, we use AutoCAD so I didn't know the file names..... thanks, I learn something every day too!!! yes,bricscad... if I remeber correcttly, in autocad the file name for those issues is ACADDOC.lsp. I made one more change, or should I say a more advanced approach: in the ON_START.LSP file I entered the lisp code without using the lisp name in this way: (foreach lt '("Center" "Center2" "Centerx2" "Hidden" "Hidden2" "Hiddenx2") (if(not(tblsearch "ltype"lt)) (command "_.-linetype" "_l" lt "iso.lin" "") ); end if ); end foreach (princ) what it dose is that the code run on startup, do what it is ment to do (load the line types in this case) but it dosn't create a custom command by the name of LLT and it dosen't load a lisp file in to memory. Edited December 29, 2022 by aridzv 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 30, 2022 Share Posted December 30, 2022 For years now did not edit acad.lsp etc but rather I have a custom lisp yes its called Autoload.lsp with all my defuns, shortcuts, (AUTOLOAD etc and yes it works with Bricscad. Just go to Appload and add it to the startup suite list, then it will autoload and run the lisp on startup. 2 Quote Link to comment Share on other sites More sharing options...
