help with lsp
leonucadomi
hello all:
I am making a routine that does the following.
1.- select a 3d solid (ent1)
2.- select other 3d solid (ent2)
after making a subtraction.
and then obtain the weight (steel) of that solid generated.
here is my code.
but something is wrong
(defun c:test (/ wtesp ent1 ent2 sol solido masa peso peso3 opp)
(vl-load-com)
(setq wtesp (* 1 7850))
(setq ent1 (entsel))
(setq ent2 (entsel))
    (command "__subtract" ent1 "" ent2 "")
(setq sol (entlast))
(setq solido (vlax-ename->vla-object (car sol)))
(setq masa (vlax-get-property solido 'Volume))
(setq peso (* masa wtesp))
(setq peso3 (/ peso 1000000000))
(setq opp (rtos peso3 2 3))
(princ "\nPeso = ")
(princ opp)
  );fin defun
entsel needs to have car because it returns the entity name and point of mouse click.
entlast doesn't need car because its just the last entity name in the drawing database.
Consolidated the code down a bit.
(defun c:test (/ ent1 ent2 v p)
  (if (and (setq ent1 (car (entsel "\nSelect 1st Solid"))) (setq ent2 (car (entsel "\nSelect 2nd Solid"))))
      (setq v (vlax-get-property (vlax-ename->vla-object (entlast)) 'Volume))
      (setq p (/ (* v 7850) 1000000000)) ;check formula this seems off
      (prompt (strcat "\nArea = " (rtos v 2 3)))
      (prompt (strcat "\nPeso = " (rtos p 2 3)))
  • Thanks 1
Need more info like is correct volume weight being used, what is units feet mm etc.
A typo ?
(prompt (strcat "\nVolume = " (rtos v 2 3)))
