mid line from center arc to center chord
land
Welcome to Cadtutor
Maybe this will help you, but if it's a polyline with more elements or it's a line this just won't work
;;; c2mpt Line from Midpoint of chord to Midpoint of an arc
;;; 20221225 Isaac A.
;;; https://www.cadtutor.net/forum/topic/76534-mid-line-from-center-arc-to-center-chord/
(vl-load-com)
(defun c:c2mpt (/ a b c d e oe oo ve)
   (setq oe (getvar 'cmdecho)
         oo (getvar 'osmode)
   (setvar 'cmdecho 0)
   (vl-cmdf "_.undo" "_begin")
   (setvar 'osmode 37)
   (princ "\nProgram to create a line from midpoint of chord to midpoint of an arc ")
   (setq e  (car (entsel "\nSelect the element: "))
         ve (vlax-ename->vla-object   e)
         a  (vlax-curve-getStartPoint ve)
         b  (vlax-curve-getEndPoint   ve)
         c  (ia:midp a b)
	 d  (if (= (cdr (assoc 0 (entget e))) "ARC")
               (vlax-curve-getPointAtDist ve (* 0.5 (vla-get-ArcLength ve)))
               (vlax-curve-getPointAtDist ve (* 0.5 (vla-get-length ve)))
   (vl-cmdf "line" "_non" c "_non" d "")
   (setvar 'osmode oo)
   (setvar 'cmdecho oe)
   (vl-cmdf "_.undo" "_end")
   (princ "\n")
;;; ia:midp
;;; Returns the midpoint of 2 given points
(defun ia:midp (a b)
  (mapcar '* (mapcar '+ a b) '(0.5 0.5 0.5))
  • Like 2
  • 3 weeks later...
