I had to convert a drawing I created in imperial units to metric.  Everything went well except when I plot with the same .stb files I had been using with imperial, the lines are all very thin.  Do I have to create a new .stb file for metric or is there a setting that I am missing somewhere?
More than likely in metric lines are say 0.18 0.25 0.35 0.5 0.75 1.0 etc start with all set to 0.25. These are the old ISO ink pen sizes.
  • 2 weeks later...
It sounds like the lineweights in your .stb file may not be scaling correctly when you switch between imperial and metric units.
Here are a few things you can try to fix the issue:
In AutoCAD, go to the "Application Menu" and select "Options"
In the "Options" dialogue box, go to the "Display" tab and ensure that the "Lineweight" option is set to "On"
Go to the "Plot and Publish" tab and make sure that the "Scale Lineweights" option is set to "Yes"
Try regenerating the drawing by going to the "Home" tab and clicking the "Regen" button
If these steps don't solve the problem, you may need to create a new .stb file that is set up specifically for use with metric units. You can do this by following these steps:
In AutoCAD, go to the "Layers" tab and click the "Layer Properties" button
In the "Layer Properties Manager" dialogue box, click the "New" button
In the "New Layer" dialogue box, enter a name for the new layer and select "Continuous" for the "Linetype"
Click "OK" to create the new layer
In the "Layer Properties Manager" dialogue box, click the "Lineweight" column for the new layer and select a lineweight from the dropdown menu
Repeat steps 4 and 5 for each layer you want to include in the .stb file
When you have finished creating the layers, go to the "File" tab and select "Save As"
In the "Save Drawing As" dialogue box, select "Save as type" as "AutoCAD Linetype (*.stb)" and give the file a name
Click "Save" to create the .stb file
You can then select this new .stb file when plotting your drawing in metric units.
I hope this helps! Let me know if you have any questions.
