hello all:
I would like to know if there is any routine that you do
1.- Select a 3d solid
2.- rotate in x axis 90 degrees.
but that the axis of rotation is the centroid of that solid
further
every time you "enter"
keep rotating 90 degrees until press  "scape"
help please
You can get centroid its a property of a solid,
;   Centroid (RO) = (23136.3 11917.7 25.0)
You should be able to use rotate3d using X axis and the centroid point
(setq ent (car  (entsel "Pick obj")))
(setq pt (vlax-safearray->list (vlax-variant-value (vla-get-centroid (vlax-ename->vla-object ent)))))
(command "rotate3d" ent "" "X" pt 90)
(defun C:R3D (/ ent pt t)
  (setq pt (vlax-get (vlax-ename->vla-object ent) 'Centroid))
  (repeat 4 ;have to hit esc to exit command
    (command "//")
Edited by mhupp
I tried but this shows me
A different approach. Press ok when happy
  (setq ans 2)
  (while (> ans 1)
   (setq ans (acet-ui-message "Correct angle ?" "PLEASE CHOOSE"  1))
(c:r3d)
