khoshravan Posted December 16, 2022 Posted December 16, 2022 Color of an Object, in a layer is not ‘ByLayer’. I try to change to ‘by layer’ through object properties but it doesn’t accept and keeps the color. What is the reason and how can I change it into another color? Quote
SLW210 Posted December 16, 2022 Posted December 16, 2022 Is the object a block? Can you post the .dwg? Quote
mhupp Posted December 16, 2022 Posted December 16, 2022 (edited) Is the layer locked, xref, or like SLW210 said a block? Edited December 16, 2022 by mhupp Quote
khoshravan Posted December 17, 2022 Author Posted December 17, 2022 On 12/16/2022 at 11:13 AM, SLW210 said: Is the object a block? Can you post the .dwg? I can post the dwg tomorrow but yes it is a block. Could you please answer in case it is block? In the same line I have the next question. Is it possible to unblock a block? How? Quote
khoshravan Posted December 17, 2022 Author Posted December 17, 2022 On 12/16/2022 at 3:39 PM, mhupp said: Is the layer locked, xref, or like SLW210 said a block? Yes it is a block. How can I solve this issue? Quote
ReMark Posted December 17, 2022 Posted December 17, 2022 Insert the block, explode the block, use CHPROP to change the color of the object in question, redefine the block and select the objects that made up the original block. 1 Quote
Cad64 Posted December 17, 2022 Posted December 17, 2022 On 12/17/2022 at 4:33 AM, khoshravan said: In the same line I have the next question. Is it possible to unblock a block? How? You can edit the block with the REFEDIT command or The BEDIT command. From there you can make changes to the block, then save and exit the editor to update the changes to the block. 1 1 Quote
tombu Posted December 18, 2022 Posted December 18, 2022 Only way to pick a block and change it color with object properties is setting the properties of block objects to Layer 0 and color to ByBlock instead of ByLayer. The link above describes it as well as I've seen anywhere. 1 Quote
