hello:
I use this routine to know the scale and then get inside
The problem is that after I return to paper space
and I try to select another window and it selects the first one
can that be solved?
help please.
defun c:test (/)
  ;inicio de la rutina
 (setq old_err *error*)(defun *error* ( a / )(princ "") (setq *error* old_err)(princ))
(setvar "cmdecho" 0)
(if (and (setq EntVP (car (entsel "\Seleccione VIEWPORT: ")))
(= (cdr (assoc 0 (entget EntVP))) "VIEWPORT"))
(setq EscVP (vla-get-CustomScale (vlax-ename->vla-object EntVP)))
(setq StrScale (rtos (/ 1 EscVP) 2 2)
(Prompt (strcat "\nLa escala de La Ventana es 1/" StrScale))
(setq inv-vps (/ 1 EscVP))
(setvar "cmdecho" 1)
(terpri)
(princ EscVP)
(terpri)
(princ StrScale)
(terpri)
(command "_.MSPACE")
Try this .. you need to get the viewport ID ( DXF code 69 ).
(defun c:test (/ *error* entvp escvp inv-vps old_err strscale) ;inicio de la rutina
  ;;(setq old_err *error*)
  ;;(defun *error* (a /) (princ "") (setq *error* old_err) (princ))
  ;;(setvar "cmdecho" 0)
  (if (and (setq entvp (car (entsel "\Seleccione VIEWPORT: ")))
	   (= (cdr (assoc 0 (entget entvp))) "VIEWPORT")
    (progn (setq escvp (vla-get-customscale (vlax-ename->vla-object entvp)))
	   (setq strscale (rtos (/ 1 escvp) 2 2))
	   (prompt (strcat "\nLa escala de La Ventana es 1/" strscale))
	   ;; You need to set the viewport ID after going into floating modelspace
	   (setvar 'cvport (cdr (assoc 69 (entget entvp))))
  (setq inv-vps (/ 1 escvp))
  ;;(setvar "cmdecho" 1)
  (terpri)
  (princ escvp)
  (terpri)
  (princ strscale)
  (terpri)
BTW .. the code you posted above is missing parenthesis so not sure how you're using it? 🤔
Edited by ronjonp
  • Funny 1
thanks that was very helpful
How Can I change  the current viewport while in paper space?
How can this value be changed?
I put a comment in the code:
Quote
What are you trying to accomplish?
Try this.
(defun c:test (/ ss escvp strscale)
  (setvar 'cvport 1)  ;goes into PAPERSPACE automatically
  (if (setq ss (ssget "_+.:E:S" '((0 . "VIEWPORT"))))  ;only allows you to pick a viewport
      (setq escvp (vla-get-customscale (setq vp (vlax-ename->vla-object (ssname SS 0))))
      (setvar 'cvport (cdr (assoc 69 (entget (ssname SS 0)))))
      (prompt (strcat "\nLa escala de La Ventana es 1/" strscale " = " (rtos escvp 2)))
  • Thanks 1
