break at a point....help
hello:
I want to run break command from lsp
the problem is that I want to break only at one point and it breaks me at two points
when i write break in the command line
this is shown
I use this line
(command "_break" "\\" "\\" "")
but I would like to break only at one point without having to use the icon
any suggestions?
(command "_BREAK" (car (entsel "\nSelect Entity")) (getpoint "\nBreak at point") "@")
Edited by mhupp
  • Thanks 1
  • 3 weeks later...
(DEFUN c:PartirEnPunto ()
  (PRINC "\n")
  (COMMAND "_.break" pause "_f" pause "@")
  (PRIN1)
this is what I use to break by one point:
(defun c:Brk_Fp ()
 (if (and
       (setq ss (ssget ":S"))
       (setq pt (getpoint "\nSelect break point: "))
   (setq ename (ssname ss 0))
   (command "_.break" ename "_none" pt "_none" pt)
I recently just saw this post and I've been trying my best to try to recursively break a polyline at points (in a list) that may or may not be on it.
So far, no luck. I'll sleep on it a while.
There is a new BREAKATPOINT command that does this.
I made an alias of BAP for it
Edited by troggarf
Spelling
  • Like 2
  • 2 weeks later...
On 12/13/2022 at 5:05 PM, leonucadomi said:
hello:
this is shown
I use this line
any suggestions?
Hi, I use
(defun c:bn ()(command "break" PAUSE "F"))
to break at 2 points, but at one point
(defun c:nm ()
(setq p1 (getpoint "Punto de corte..."))
(command "break" pause "F" p1 p1)
its not a great solution, but may be you think a another best solution!!!
  • 8 months later...
Quick and dirty code - (no error checking no data validation)
(setq brekData (nentsel "\nClick break point: "))
(setq entToBrek (car brekData))
(setq brekPt (cadr brekData))
(command "_.Break" entToBrek brekPt brekPt)
