extract value of block...help
can someone help me to extract the value of the attributes inside a block?
Here I put the example of the block that I use.
I want to extract the value "2000" and put it in a variable.
thank you for your advices
BLOCK.dwg
getproperyvalue doesn't work in BricsCAD so I can't test this.
This will ask you to select a block and if it has DAT2 attribute it will
1 set variable x to its value (can be called later)
2 copy that value to the clipboard (ctr+V to paste)
(defun C:foo (/ html)
  (vl-load-com)
  (if (setq x (getpropertyvalue (car (entsel "\nSelect Block")) "DAT2"))
    (vlax-invoke (vlax-get (vlax-get (setq html (vlax-create-object "htmlfile")) 'ParentWindow) 'ClipBoardData) 'setData "Text" x)
  (vlax-release-object html)
another
(defun LM:vl-getattributevalue ( blk tag );LEE MAC
    (setq tag (strcase tag))
    (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (vla-get-textstring att))) (vlax-invoke blk 'getattributes))
(defun c:sel_block ()
  (while (setq obj_block (vlax-ename->vla-object (car (entsel "\nSelecciona bloque: "))))
    (setq dato2 (LM:vl-getattributevalue obj_block "DATO2"))
    (princ dato2)
this is great thanks for your help
If you are happy to pick an attribute directly then can do this. Uses Nentsel rather than entsel.
(setq attstr (cdr (assoc 1 (entget (car (nentsel "\nPick attribute "))))))
  • Like 2
