I was trying to see if I could hatch objects inside a block with a solid hatch.
Any help would be appreciated.
Here's what I have so far:
(defun c:test (/ ss1 blkn cnt var_cmdecho)
  (prompt "\nSelect blocks to hatch with solid hatch: ")
  (if (setq ss1 (ssget '((0 . "INSERT"))))
      (setq cnt 0)
      (setq var_cmdecho (getvar 'cmdecho))
      (setvar 'cmdecho 0)
      (repeat (setq cnt (sslength ss1))
        (setq cnt  (1- cnt)
              blkn (cons (vla-get-effectivename (vlax-ename->vla-object (_dxf -1 (entget (ssname ss1 cnt))))) blkn)
      (setq blkn (_removedup blkn))
      (foreach x blkn
        (command "-bedit" x)
        (initcommandversion)
        (sssetfirst nil (ssget "_ALL"))
        (command "_.bhatch" "_P" "_S" "_LA" "." "_advanced" "_associativity" "_yes" "" "_select" "_last" "" "")
        (command "_.bsave")
        (command "_.bclose")
        (redraw)
      (setvar 'cmdecho var_cmdecho)
;; removes duplicate element from the list
(defun _removedup (l)
  (if l
    (cons (car l) (_removedup (vl-remove (car l) (cdr l))))
(c:test)
On 12/9/2022 at 7:15 PM, lido said:
Function undefined: _dxf, initcommandversion.
Rookie error, but:
With
(command "_.bhatch" "_P" "_S" "_LA" "." "_advanced" "_associativity" "_yes" "" "_select" "_all" "" "")
;; or
 (vl-cmdf "_.bhatch" "_P" "_S" "_LA" "." "_advanced" "_associativity" "_yes" "" "_select" "_all" "" "")
it works when I open the same block and hatches successfully but with the code below and selecting the block it doesn't and gets stuck at the hatch dialog.
(vl-load-com)
; Tharwat 18th Sept 2013
; Modified on 2022.12.09 by 3dwannab to hatch circles and closed polylines entities in a block
; https://www.cadtutor.net/forum/topic/46782-deleting-hatch-from-blocks/?do=findComment&comment=396412
(defun c:BKHatchAll_Solid (/ ss1 blkn cnt var_cmdecho)
      (setq cnt 0)
      (setvar 'cmdecho 0)
        (setq cnt  (1- cnt)
      (foreach x blkn
        (command "_.bsave")
        (redraw)
  (if l
;; _dxf
;; Finds the association pair, strips 1st element
;; args   - dxfcode elist
;; Example  - (_dxf -1 (entget (ssname (ssget) 0)))
;; Returns  - <Entity name: xxxxxxxxxxx>
(defun _dxf (code elist)
  (cdr (assoc code elist))
(c:BKHatchAll_Solid)
Edited by 3dwannab
Not had a chance to look at this but what happens if you comment out the (command "_.bhatch line? Does it finish the rest of the routine?
Yup. That hatch command is a strange one how it works on its own.
@3dwannab Try replacing "BHATCH" with "-HATCH":
(command "_.-hatch" "_P" "_S" "_LA" "." "_advanced" "_associativity" "_yes" "" "_select" "_all" "" "")
Tested and works for me.
Edited by pkenewell
Perfect @pkenewell, thanks a lot.
Here's the working version. I don't know if I remember if there was a vla-get to get items that can be hatched. But for now this brute force method works.
(vl-load-com)
; Modified on 2022.12.12 by 3dwannab to hatch everything inside the block. Help over here: https://www.cadtutor.net/forum/topic/76450-hatch-objects-inside-a-block/
;; TO DO: Only hatch entities that can be hatched. Think there may be a vla-get for this. Not sure.
(defun c:BKHatchAll_Solid (/ *error* acDoc blkn cnt ss1 var_cmdecho var_osmode)
  (defun *error* (errmsg)
    (and acDoc (vla-EndUndoMark acDoc))
    (and errmsg
         (not (wcmatch (strcase errmsg) "*CANCEL*,*EXIT*"))
         (princ (strcat "\n<< Error: " errmsg " >>\n"))
    (setvar 'osmode var_osmode)
  (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (or (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc))
  (setq var_cmdecho (getvar "cmdecho"))
  (setq var_osmode (getvar "osmode"))
  (setvar 'cmdecho 0)
  (setvar 'osmode 0)
      (setq cnt 0)
        (setq cnt  (1- cnt)
      (foreach x blkn
        (command "_.bsave")
        (redraw)
  (*error* nil)
  (if l
;; _dxf
; (c:BKHatchAll_Solid)
