gsc Posted December 7, 2022 Posted December 7, 2022 Hi, In my LISP routine 4 (large) lists needs to be written to 4 CSV files. Is it possible to run 4 write actions at the same time? If this is not possible how do I run them after each other, where one write action is finished before the next starts? Quote
Steven P Posted December 7, 2022 Posted December 7, 2022 (edited) Try it and see - best way to learn what works! Remembering to call each a unique name and reference within the LISP By way of example, from Lee Mac - commenting out some of the nice stuff he puts in (defun c:writetextfile ( / des txt ) ;; Define function, declare local variables ;; (if (setq txt (getfiled "Create Text File" "" "txt" 1)) ;; Prompt user for filename/filepath ;; (progn (setq txt1 (getfiled "Create Text File" "" "txt" 1)) (setq txt2 (getfiled "Create Text File" "" "txt" 1)) (setq txt3 (getfiled "Create Text File" "" "txt" 1)) ;; (if (setq des (open txt "w")) ;; Attempt to create text file with given filename/filepath (progn ;; Evaluate the enclose expressions as the 'then' expression for the IF statement (setq des1 (open txt1 "w")) ;; Attempt to create text file with given filename/filepath (setq des2 (open txt2 "w")) ;; Attempt to create text file with given filename/filepath (setq des3 (open txt3 "w")) ;; Attempt to create text file with given filename/filepath (write-line "This is a test 1." des1) ;; Write line of text to text file (write-line "This is a test 2." des2) ;; Write line of text to text file (write-line "This is a test 3." des3) ;; Write line of text to text file (close des3) ;; Close file descriptor (close des2) ;; Close file descriptor (close des1) ;; Close file descriptor ) ;; end PROGN ;; (princ "\nUnable to create text file.") ;; Else the text file could not be created ;; ) ;; end IF ;; (princ "\n*Cancel*") ;; Else the user pressed Cancel ;; ) ;; end PROGM ;; ) ;; end IF (princ) ;; Suppress the return of the last evaluated expression ) ;; end DEFUN Edited December 7, 2022 by Steven P 1 Quote
gsc Posted December 7, 2022 Author Posted December 7, 2022 I have used unique variables like you proposed, testing right now Quote
