Lisp works only when certain conditions are established...
cadmaster1004
Hi, guys. I want to ask you a question.
There's a block named A
And there's a block with names A, B, C, D
First, select block A and then block A, B, C, and D at once (mouse drag)
I'm looking for a lisp that generates text only on block A
In other words, I want to study Lisp that only works on block A.
Please take good care of me. I hope you stay healthy!
Edited by cadmaster1004
As far as I know , you can have only one block named A . please upload sample-dwg ,  before and after .
11 hours ago, devitg said:
As far as I know , you can have only one block named A.
One definition of block A in the block library, But you can have multiples of block A in the drawing.
This should be what your looking for. Added two other lisp that will dump properties of selected items into command prompt.
dumpit = dxf codes
Vdumpit = visual lisp propeties
;; Select Block by Name
(defun C:SBN (/ blkname SS)
  (setq blkname (cdr (assoc 2 (entget (car (entsel "\nSelect Block")))))) ;Gets block name to use in ssget filter
  (if (setq SS (ssget (list '(0 . "INSERT") (cons 2 blkname)))) ;will only select blocks of the same name
    (sssetfirst nil SS)
;; Dump all methods and properties for selected objects
(defun C:VDumpIt (/ ent)
  (while (setq ent (car (entsel "\nSelect Entity to Dump")))
    (vlax-Dump-Object (vlax-Ename->Vla-Object ent) t)
  (textscr)
;; Dump all DXF Group Data
(defun C:DumpIt (/ ent)
    (mapcar 'print (entget ent '( "*")))
  (textscr)
Edited by mhupp
  • Like 3
I took that to mean select block A to be the reference block and then select all blocks, filtering so that only instances of block A are selected. Like MHUPP says, you can have many instances of a block inserted (but only 1 definition of it)
Edited by Steven P
I am sorry for my poor English.
But thank you for letting me know.
I'll study it with that cord
dumpit = dxf codes
  (prompt "\nSelect Polyline")
    (sssetfirst nil SS)
  (textscr)
  (textscr)
Maybe this will make a selection set of blocks with 1 name only.
(setq BNAME (cdr (assoc 2 (entget (car (entsel "\nPick block for name "))))))
(setq ss (ssget (list (cons 0 "INSERT")(cons 2 bname))))
