davenutron Posted December 3, 2022 Share Posted December 3, 2022 I can only snap to the center of a cylinder, how to get snaps for every quarter of the circle Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 3, 2022 Share Posted December 3, 2022 (edited) Here we go again. You need to enable the QUADrant Osnap. All this information is readily available at your fingertips if only you would 1) make the effort and 2) use AutoCAD Help. Press <Shift> and right-click in the drawing area, then choose an object snap mode from the Object Snap menu that appears. Right-click OSNAP on the status bar, and then click Object Snap Settings… Edited December 4, 2022 by ReMark 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted December 4, 2022 Share Posted December 4, 2022 I think nearest would work too. Quote Link to comment Share on other sites More sharing options...
CadAuto Posted January 2, 2023 Share Posted January 2, 2023 To enable snaps at the quarter points of a circle in AutoCAD, you will need to customize the "Snap Settings" for your drawing. Here's how: In AutoCAD, go to the "Status Bar" and click the "Snap Mode" button to turn on snap mode Right-click the "Snap Mode" button and select "Snap Settings" from the context menu In the "Snap and Grid Settings" dialogue box, go to the "Snap" tab Under "Snap Type," select "Polar" Under "Polar Snap," check the box next to "Quadrant" to enable snaps at the quarter points of a circle Click "OK" to close the "Snap and Grid Settings" dialogue box Now, when you move your cursor over the circumference of a circle, you should see snaps appear at the quarter points. I hope this helps! Let me know if you have any questions. Quote Link to comment Share on other sites More sharing options...
