Cad64 Posted December 3, 2022 Posted December 3, 2022 One way would be to select the arc in Object Mode, then switch to Edit Mode, click and drag a window around the arc you want to delete, then hit "X" on your keyboard or hit the "Delete" key. This will open a pop-up window. Select "vertices" or "segments" and the arc should disappear. Quote
