leonucadomi Posted December 1, 2022 Posted December 1, 2022 hello friends: Does anyone have a routine to modify the size of the texts in this block? I want to modify these three text sizes for one that I previously decide. somebody help me please. block.dwg Quote
ronjonp Posted December 1, 2022 Posted December 1, 2022 Open in the block editor, make your changes then run attsync on it. 1 Quote
Steven P Posted December 2, 2022 Posted December 2, 2022 For a single block I would do as RonJon, just edit the block and attsync. A LISP and other automation works best to do the same action many times with minimal user input. How many blocks are you wanting to change by the way? Is it just a single block, many, or do you need to do this frequently? (writing, testing and verifying that a LISP works as expected takes some time, which might not be a time saving if you are only ever going to do this once or twice) Quote
leonucadomi Posted December 2, 2022 Author Posted December 2, 2022 It is not a single block, there are many and in many drawings, for that reason I am looking for a lisp 1 Quote
leonucadomi Posted December 2, 2022 Author Posted December 2, 2022 I found this but it changes the width and I'm looking to change the text size....:( (vl-load-com) (defun C:BTW ; = Block Text Width (/ width blk ent) (setq width (getreal "\nWidth factor for all Text/Attributes: ")) (setq blk (tblnext "block" t)); first one in Table (while blk (if (= (logand 20 (cdr (assoc 70 blk))) 0); not an Xref [4] or Xref-dependent [16] (progn ; then -- process this Block (setq ent (cdr (assoc -2 blk))); first object in Block definition (while ent (if (wcmatch (cdr (assoc 0 (entget ent))) "TEXT,ATTDEF") (vlax-put (vlax-ename->vla-object ent) 'ScaleFactor width) ); if (setq ent (entnext ent)); next object ); while ); progn ); if (setq blk (tblnext "block")); next one in Table ); while (command "_.attsync" "_name" "*"); update width in Block Attributes, if any (princ) ); defun Quote
Steven P Posted December 2, 2022 Posted December 2, 2022 I reckon..... if you read through the code.... (setq width .... ) gets the user to input the width - so if you look after that where 'width' is used it will give you a clue? Aha!! "(vlax-put (vlax-ename->vla-object ent) 'ScaleFactor width)".. wonder what would happen if you took a guess and used "Height" instead of "ScaleFactor" ? Lets try.... if it all goes wrong wait for another to answer? (defun C:BTH ; = Block Text Height (/ width blk ent) (setq width (getreal "\nHeight for all Text/Attributes: ")) (setq blk (tblnext "block" t)); first one in Table (while blk (if (= (logand 20 (cdr (assoc 70 blk))) 0); not an Xref [4] or Xref-dependent [16] (progn ; then -- process this Block (setq ent (cdr (assoc -2 blk))); first object in Block definition (while ent (if (wcmatch (cdr (assoc 0 (entget ent))) "TEXT,ATTDEF") (vlax-put (vlax-ename->vla-object ent) 'height width) ); if (setq ent (entnext ent)); next object ); while ); progn ); if (setq blk (tblnext "block")); next one in Table ); while (command "_.attsync" "_name" "*"); update width in Block Attributes, if any (princ) ); defun Though as it is, this routine does the change globally for all blocks in the drawing with no selection possible and all attributes in those blocks. It could be a good start for you to then ask "I found this, and changed it to modify text heights, but how could I get it to do this....?" Quote
leonucadomi Posted December 2, 2022 Author Posted December 2, 2022 use this code to enter the desired height but it is manually, I would like to do it selecting by window. remembering that the attribute is in a block reference (defun C:test ( / e h ) (setq h (getdist "\nEnter height of text:")) (repeat 100 (setq e (vlax-ename->vla-object (car (nentsel "\n Select an attribute to change:")))) (vla-put-height e h) ); repeat (princ) ) Quote
ronjonp Posted December 2, 2022 Posted December 2, 2022 (edited) Try this: (defun c:foo (/ b c h n s) ;; RJP » 2022-12-02 (cond ((and (or (setq h (getdist "\nEnter height:<1> ")) (setq h 1)) (setq s (ssget '((0 . "INSERT") (66 . 1)))) ) (setq b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))) (setvar 'cmdecho 0) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq n (vla-get-effectivename (vlax-ename->vla-object e))) (or (member n c) (progn (vlax-for a (vla-item b n) (if (= "AcDbAttributeDefinition" (vla-get-objectname a)) (progn (vl-catch-all-apply 'vlax-put (list a 'height h)) (setq c (cons n c))) ) ) (command "_.Attsync" "Name" n) ) ) ) (setvar 'cmdecho 1) ) ) (princ) ) (vl-load-com) And with your code, use WHILE rather than REPEAT. Also check that the item has a height property AND can be modified before trying to set it. (defun c:test (/ e h) (or (setq h (getdist "\nEnter height of text:<1> ")) (setq h 1)) (while (setq e (car (nentsel "\nSelect an attribute to change:"))) (if (and (vlax-property-available-p (setq e (vlax-ename->vla-object e)) 'height) (vlax-write-enabled-p e) ) (vla-put-height e h) ) ) (princ) ) Edited June 7, 2023 by ronjonp 2 Quote
Steven P Posted December 2, 2022 Posted December 2, 2022 1 hour ago, leonucadomi said: use this code to enter the desired height but it is manually, I would like to do it selecting by window. remembering that the attribute is in a block reference (defun C:test ( / e h ) (setq h (getdist "\nEnter height of text:")) (repeat 100 (setq e (vlax-ename->vla-object (car (nentsel "\n Select an attribute to change:")))) (vla-put-height e h) ); repeat (princ) ) Just a point, to put your code with the grey background use the <> button and copy it to the pop up window, it makes it easier to see what is code and what isn't 'Test' you posted doesn't change the block definition, just the text entered into the attributes - try and see, run it and set a height and then 'attsync' what you just changed, it pops back to how it was, similarly copy 2 of the same block and try it on one, it will only change the one you select. Quote
mhupp Posted December 2, 2022 Posted December 2, 2022 (edited) FYI You will need to Regen to see changes if selecting with nentsel (defun c:test (/ ADoc e h) (setq ADoc (vla-get-ActiveDocument (vlax-get-Acad-Object))) (or (setq h (getdist "\nEnter height of text:<1> ")) (setq h 1)) (while (setq e (car (nentsel "\nSelect an attribute to change:"))) (if (and (vlax-property-available-p (setq e (vlax-ename->vla-object e)) 'height) (vlax-write-enabled-p e) ) (vla-put-height e h) ) (vla-Regen ADoc acActiveViewport) ) (princ) ) Edited December 2, 2022 by mhupp Code Updated Quote
Steven P Posted December 2, 2022 Posted December 2, 2022 (edited) Just for fun... this is one I modified from Lee Macs AttCol LISP. All credit to him ( http://www.lee-mac.com/attributecolour.html ) This one will modify the text height in selected blocks (not the block definitions). I haven't changed the errors or anything like that, if it doesn't work as expected probably my fault (Same way that your 'test' LISP does but not block definition that your BTW or RonJons FOO does) ;;-------------------=={ Attribute Height }==-----------------;; ;; ;; ;; Prompts for a selection of attributed blocks and displays ;; ;; a dialog interface enabling the user to change the text ;; ;; height of specific attribute tags. ;; ;;------------------------------------------------------------;; ;; www.lee-mac.com ;; ;; ;; ;; Modified from Lee Mac ATTCOL LISP ;; ;;------------------------------------------------------------;; ;;LISP ROUTINES ;; ;;ATTHEIGHT Change block tag attribute layers ;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;This line loads Visual Lisp / ActiveX (vl-load-com) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun c:AttHEIGHT ( / *error* _StartUndo _EndUndo _unique _dclsel doc l lst s ss acount attheight) ;; ATTCOL © Lee Mac 2011 & Modified into ATTLAY by SP ;;*error* For errors ;; _StartUndo For unfo ;; _EndUndo For undo ;; _unique To check if tags are unique ;; _dclsel ;; doc ;; l List of tags ;; lst List of layers ;; s Used once to check if tags are unique? ;; ss Used for selecting objects ;; acount A counter, for loops etc ;; mylayer ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;Initial Values (setq attheight 0) ;; First time default height (setq acount 0) ;; Set counter to 0 ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;Sub routines ;;Error Functions (defun *error* ( msg ) (if doc (_EndUndo doc)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) ;;Undo functions (defun _StartUndo ( doc ) (_EndUndo doc) (vla-StartUndoMark doc) ) (defun _EndUndo ( doc ) (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-EndUndoMark doc) ) ) ;;Checks if l is unique (defun _unique ( l ) (if l (cons (car l) (_unique (vl-remove (car l) (cdr l)))))) ;;; returns the Layers object (defun get-layrobj () (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object) ) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;Makes DCL box (defun _dclsel ( l / file tmp dch tagreturn) (cond ( (not ;; (and (setq file (open (setq tmp (vl-filename-mktemp nil nil ".dcl")) "w")) (and (setq file (open (setq tmp (strcat (getvar "TEMPPREFIX") "Attlay.dcl")) "w")) (write-line (strcat "attlay : dialog { label = \"Attribute Layer\"; spacer; width = 35;" ": boxed_column { label = \"Tags\";" " : row { " " : list_box { label = \"Select Tag(s)\"; key = \"tags\"; width = 30; multiple_select = true ; alignment = centered; }" " }" " : row { " " : button { label = \"Select All\"; key = \"ButSel\";}" " : button { label = \"Clear All\"; key = \"ButClear\";}" " }" "}" " : boxed_row { label = \"Height\"; " " : column { width = 15;" " : text { label = \"Enter Height\";}" " }" " : column { width = 20;" " : edit_box { key = \"sel\"; edit_width = 10; alignment = centered; label = \"\"; value = \"2.5\";}" " }" " }" " : boxed_row { alignment = centered; label = \"OK\";" " spacer; ok_cancel;" " }" "}" ) file ) (not (close file)) (< 0 (setq dch (load_dialog tmp))) (new_dialog "attlay" dch) ) ) ) (t ;;create tags list (start_list "tags") (mapcar 'add_list l) (end_list) ;;creates tag list in list box (setq tagreturn (set_tile "tags" "0")) ;;highlights tag at position '0' in list box ;;Create layers list (vlax-for acount (get-layrobj) (setq lst (cons (vlax-get-property acount 'Name) lst)) ) (setq lst (acad_strlsort lst)) ;;Actions from DCL Form (action_tile "tags" "(setq tagreturn $value)") ;;tagreturn here is position number (action_tile "sel" "(setq attheight (get_tile \"sel\"))") (action_tile "ButSel" "(SelectAll (length l))") (action_tile "ButClear" "(clearAll)") ;;how to check if a layer has been selected? ;;set tagreturn, creates list of selected tags positions (eg. "0 1 3 4 5 9 10") (setq tagreturn (if (= 1 (start_dialog)) (mapcar '(lambda ( x ) (nth x l)) (read (strcat "(" tagreturn ")"))) ) ) ) ) (if (< 0 dch) (unload_dialog dch)) ;;closes DCL box (if (setq tmp (findfile tmp)) (vl-file-delete tmp)) ;;closes DCL box tagreturn ) ;;End of DCL Box ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;magic stuff (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (if (and (ssget "_:L" '((0 . "INSERT") (66 . 1))) (progn (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc)) (foreach att (append (vlax-invoke obj 'GetAttributes) (vlax-invoke obj 'GetConstantAttributes)) (setq l (cons (cons (vla-get-TagString att) att) l)) ) ) (vla-delete ss) (setq s (_dclsel (acad_strlsort (_unique (mapcar 'car l))))) ) ) (progn (_StartUndo doc) (foreach pair l (if (vl-position (car pair) s) (vla-put-height (cdr pair) attheight))) (setq mylayer 0) (_EndUndo doc) ) (princ "\n*Cancel*") ) (princ) ) Edited December 3, 2022 by Steven P Add link to original code Quote
3dwannab Posted June 7, 2023 Posted June 7, 2023 On 12/2/2022 at 8:12 PM, Steven P said: Just for fun... Hi @Steven P, thanks for this but when I run an attribute sync on that block again the text reverts to its original. I looked at the code but couldn't see anything that was causing this. 1 Quote
Steven P Posted June 7, 2023 Posted June 7, 2023 the first one I posted, BTH, or the 2nd one, AttHeight ? Attheight doesn't change the block definition, just the way that instance of that block is displayed - so when you attsync that it goes bat the block definition sizes . BTH should update the block definition, and so Attsync shouldn't affect it 1 Quote
Steven P Posted June 7, 2023 Posted June 7, 2023 Yes, that one just changes the text height for that block instance and not the block definition. I'd need to have a good think how to modify that to suit - not sure I'll get time to do that though! Maybe one of the other codes above will do what you want? Quote
ronjonp Posted June 7, 2023 Posted June 7, 2023 4 hours ago, 3dwannab said: Hi @Steven P, thanks for this but when I run an attribute sync on that block again the text reverts to its original. I looked at the code but couldn't see anything that was causing this. THIS modifies the block definition. 1 Quote
3dwannab Posted June 7, 2023 Posted June 7, 2023 1 hour ago, ronjonp said: THIS modifies the block definition. I ended up using this. I did like the dialog Steven used to allow the selection of each attribute but I'd say 999/1000 I'd need this. Quote
ronjonp Posted June 7, 2023 Posted June 7, 2023 48 minutes ago, 3dwannab said: I ended up using this. I did like the dialog Steven used to allow the selection of each attribute but I'd say 999/1000 I'd need this. I updated the code above so ATTSYNC will only be called once per block name. 2 Quote
