leonucadomi Posted November 28, 2022 Posted November 28, 2022 hello: I would like to know why when generating a block with this routine it sometimes changes position. (defun c:gg () (setq bpt (getpoint "\nPick Insertion point: ")) (setq ss (ssget)) (setq os (getvar "osmode")) (command "COPYBASE" bpt ss "" "erase" "p" "") (setvar "osmode" 0) (command "pasteblock" bpt ) (setvar "osmode" os) (princ) ) I would like to select objects and make them block in their place. Quote
mhupp Posted November 29, 2022 Posted November 29, 2022 Move osmode 0 before the block command. Could be snapping to something when copybase is called. or just use "_non" so snaps are ignored. ;;----------------------------------------------------------------------------;; ;; Make Quick Block (defun C:QB () (setq bpt (getpoint "\nPick Insertion point: ")) (setq ss (ssget)) (command "COPYBASE" "_non" bpt ss "") (command "Erase" ss "") (command "pasteblock" "_non" bpt) (princ) ) 1 Quote
