Combine vl-position with wcmatch, or member with wcmatch
Hi all, got myself a tricky one...
I got a list, with an order, this is just an example.. total list is over 150 items long
(setq ordertable
		(list
			"*STONE-*"
			"*EARTH-*"
			"*PIPES-*"
I got 2 symbols:
(setq enlay "TEST-STONE-NEW")
(setq enlaydouble "DEFAULT-PIPES-NEW")
I got a lot of double lines, i want to 'overkill' them, but keep the layer, highest in the ordertable...
So i made this code:
(if (< (vl-position enlay ordertable)(vl-position enlaydouble ordertable))
		(entdel enseldouble)
		(entdel ensel)
This works, when the ordertable is not having any wildcards.
I cannot get this to work, with it accepting wildcards....
Any suggestions?
So... i need to determine with of the 2 items to delete, based on this position in the ordertable... with usage of wildcards...
Thanks in advance!
Perhaps!
(setq ordertable
		(list
			"*STONE-*"
			"*EARTH-*"
			"*PIPES-*"
(if
		(car (vl-remove nil (mapcar '(lambda (x) (if (wcmatch enlay x) (vl-position x ordertable))) ordertable)))
		(car (vl-remove nil (mapcar '(lambda (x) (if (wcmatch enlaydouble x) (vl-position x ordertable))) ordertable)))
		(print "(entdel enseldouble)")
		(print "(entdel ensel)")
)(prin1)
