barristann Posted November 26, 2022 Share Posted November 26, 2022 (edited) Hi all. This Lee Mac's code to Stretch with .y coordinate filter. Please help me modify this to select by Crossing Polygon by default (instead of having to press cp). Thank you in advance. (defun c:yst (/ *error* vl ov ss pt1 pt2) (defun *error* (msg) (if ov (mapcar 'setvar vl ov)) (if (not (wcmatch (strcase msg) "*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " msg " >>"))) (princ)) (setq vl '("CMDECHO" "OSMODE") ov (mapcar 'getvar vl)) (mapcar 'setvar vl '(0 255)) (if (setq ss (ssget)) (if (and (setq pt1 (getpoint "\nSelect Base Point: ")) (setq pt2 (getpoint pt1 "\nSelect Second Point: "))) (progn (setvar "OSMODE" 0) (command "_.stretch" ss "" pt1 ".y" pt2 0))) (princ "\n<< Nothing Selected >>")) (mapcar 'setvar vl ov) (princ)) https://www.cadtutor.net/forum/topic/11885-help-with-stretch-lisp/ Edited November 26, 2022 by barristann Quote Link to comment Share on other sites More sharing options...
Steven P Posted November 26, 2022 Share Posted November 26, 2022 Would this link help? http://www.lee-mac.com/ssget.html might be something in there? Quote Link to comment Share on other sites More sharing options...
barristann Posted November 26, 2022 Author Share Posted November 26, 2022 I've tried ssget "_CP" but it's not working (defun c:yst (/ *error* vl ov ss pt1 pt2) (defun *error* (msg) (if ov (mapcar 'setvar vl ov)) (if (not (wcmatch (strcase msg) "*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " msg " >>"))) (princ)) (setq vl '("CMDECHO" "OSMODE") ov (mapcar 'getvar vl)) (mapcar 'setvar vl '(0 255)) (if (setq ss (ssget "_CP" )) (if (and (setq pt1 (getpoint "\nSelect Base Point: ")) (setq pt2 (getpoint pt1 "\nSelect Second Point: "))) (progn (setvar "OSMODE" 0) (command "_.stretch" ss "" pt1 ".y" pt2 0))) (princ "\n<< Nothing Selected >>")) (mapcar 'setvar vl ov) (princ)) Quote Link to comment Share on other sites More sharing options...
Steven P Posted November 26, 2022 Share Posted November 26, 2022 Would you need to define the points in the ssget, like the example? You might need to add a step in to the LISP using 'getpoint' to create this list of points Quote Link to comment Share on other sites More sharing options...
barristann Posted November 26, 2022 Author Share Posted November 26, 2022 Thank you for your suggestion Steven, but I'm new to Lisp so I have no clue how to do this. I've spend 2 days guessing and searching other posts but I'm still failing... Quote Link to comment Share on other sites More sharing options...
Steven P Posted November 27, 2022 Share Posted November 27, 2022 I'll have a look at this later - should be an easy thing to add in. For now though, try putting a few coordinates into the ssget "_cp" and see how that works, use the example from Lee Mac for the formatting - once you understand that it should follow how to add your own points in there Quote Link to comment Share on other sites More sharing options...
barristann Posted November 27, 2022 Author Share Posted November 27, 2022 I'll follow your suggestion, Steven. This will increase my work productivity significantly if successful. Quote Link to comment Share on other sites More sharing options...
Tsuky Posted November 27, 2022 Share Posted November 27, 2022 Not use "CP" but simply "C" with 2 points (defun c:yst (/ *error* vl ov ss pt1 pt2) (defun *error* (msg) (if ov (mapcar 'setvar vl ov)) (if (not (wcmatch (strcase msg) "*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " msg " >>"))) (princ)) (setq vl '("CMDECHO" "OSMODE") ov (mapcar 'getvar vl)) (mapcar 'setvar vl '(0 255)) (initget 1) (setq pt1 (getpoint "\nSelect Base Point: ")) (initget 33) (setq pt2 (getcorner pt1 "\nSelect Second Point: ")) (if (setq ss (ssget "_C" pt1 pt2)) (progn (setvar "OSMODE" 0) (command "_.stretch" ss "" pt1 "_y" pt2 0)) (princ "\n<< Nothing Selected >>") ) (mapcar 'setvar vl ov) (princ)) Quote Link to comment Share on other sites More sharing options...
barristann Posted November 27, 2022 Author Share Posted November 27, 2022 Hi Tusky, Thank you for your help. Now, in Lee Mac's original code, when prompted to "Select objects", is there a way to automatically type "cp"? (I just want to automatically enter Crossing Polygon selection mode, instead of having to type cp all the time). Quote Link to comment Share on other sites More sharing options...
barristann Posted November 27, 2022 Author Share Posted November 27, 2022 Sorry I misspelled your name Tsuky Quote Link to comment Share on other sites More sharing options...
Tsuky Posted November 27, 2022 Share Posted November 27, 2022 If I understood your request correctly, maybe this! (defun c:yst (/ *error* vl ov p l_p ss pt1 pt2) (defun *error* (msg) (if ov (mapcar 'setvar vl ov)) (if (not (wcmatch (strcase msg) "*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " msg " >>"))) (princ)) (setq vl '("CMDECHO" "OSMODE") ov (mapcar 'getvar vl)) (mapcar 'setvar vl '(0 255)) (initget 1) (setq l_p (list (setq p (getpoint "\nGive first point of crossing: ")))) (while (setq p (getpoint p "\nNext point: ")) (setq l_p (cons p l_p)) (grdraw (cadr l_p) (car l_p) -1 1) ) (if (setq ss (ssget "_CP" l_p)) (if (and (setq pt1 (getpoint "\nSelect Base Point: ")) (setq pt2 (getpoint pt1 "\nSelect Second Point: "))) (progn (setvar "OSMODE" 0) (command "_.stretch" ss "" pt1 ".y" pt2 0))) (princ "\n<< Nothing Selected >>")) (mapcar 'setvar vl ov) (princ)) 1 Quote Link to comment Share on other sites More sharing options...
barristann Posted November 27, 2022 Author Share Posted November 27, 2022 This is what I need! But, I'm not sure why the selection area is not highlighted in green. Also, the selected items are not highlighted to indicate that they will be stretched. Other than that, this is exactly what I need. Thank you for your help Tsuky! Quote Link to comment Share on other sites More sharing options...
Tsuky Posted November 28, 2022 Share Posted November 28, 2022 Quote But, I'm not sure why the selection area is not highlighted in green. Also, the selected items are not highlighted to indicate that they will be stretched. For this use command "select" Exemple: (defun c:yst (/ *error* vl ov p l_p ss pt1 pt2) (defun *error* (msg) (if ov (mapcar 'setvar vl ov)) (if (not (wcmatch (strcase msg) "*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " msg " >>"))) (princ)) (setq vl '("CMDECHO" "OSMODE") ov (mapcar 'getvar vl)) (mapcar 'setvar vl '(0 255)) (command "_.select" "_cp") (while (not (zerop (getvar "CMDACTIVE"))) (command pause) ) (if (setq ss (ssget "_P" )) (if (and (setq pt1 (getpoint "\nSelect Base Point: ")) (setq pt2 (getpoint pt1 "\nSelect Second Point: "))) (progn (setvar "OSMODE" 0) (command "_.stretch" ss "" pt1 ".y" pt2 0))) (princ "\n<< Nothing Selected >>")) (mapcar 'setvar vl ov) (princ)) Quote Link to comment Share on other sites More sharing options...
barristann Posted November 28, 2022 Author Share Posted November 28, 2022 You're amazing! It's perfect! Thank you so much Tsuky! Quote Link to comment Share on other sites More sharing options...
Steven P Posted November 28, 2022 Share Posted November 28, 2022 grdraw - was trying to remember that one last night! Quote Link to comment Share on other sites More sharing options...
