(defun c:APV (/ ss1 Lastent TargEnt TargLayer undo obj ss of en pt ent)
 		(setq SS1 (ssadd))
 		(setq LastEnt (entlast))
		(while (setq TargEnt (car (entsel "\nSelect object on layer to select: ")))
  		(setq TargLayer (assoc 8 (entget TargEnt)))
  		(sssetfirst nil (ssget "_X" (list TargLayer)))
   		(defun *error* (msg)
      		(princ (strcat "\n** Error: " msg " **")))
	(if (and (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*LINE")))
          (setq of (getdist "\nSpecify Offset Distance: ")))
     (setq undo
       (not
         (vla-StartUndomark
           (setq doc
             (vla-get-ActiveDocument
               (vlax-get-acad-object)
     (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc))
       (mapcar
         (function
           (lambda ( o )
             (vl-catch-all-apply
               (function vla-offset) (list obj o)
         (list of (- of))
     (vla-delete ss)
	(setq undo (vla-EndUndoMark doc))
(if (setq en (entnext LastEnt))  ;adds all offsets to SS1
      (while en
        (ssadd en SS1)
        (setq en (entnext en))))
 (while (setq pt (getpoint "\nPick internal point: "))
   (command "_.-boundary" "_a" "_i" "_n" "" "" "_non" pt "")
  (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS1)))
    (entdel ent)
Hello I need some help please. I have put together this code here. the working principles of this is to do the following
Select all objects layer
Offset distance =
Offset distance =
Offsets are done in and out of every layer that is selected at the required offset distance.
Boundary command is done to work out the internal boundary of area selected
Continue onto the next boundary to select
when exiting the command the offsets that were produced are deleted the only thing to remain is the boundary lines
But there is a bit of a problem with this command as shown below
as you can see the boundary that was created in pink did not consider the white polyline in this boundary. So I thought then the polylines that are offset should be a closed shape but I dont know how to do that in lisp so if anyone knows how to do this that would be great.
I found this
https://cadtips.cadalyst.com/linear-objects/draw-a-cap-or-pipe-end?q=linear-objects/draw-a-cap-or-pi...
which I used and it is really good but it needs to close these objects automatically without me selecting anything.
I appreciate any help that can be given I appreciate it might not be possible.
Cheers
This might need a little reworking on the offset part to create a closed polyline object - which should be OK after that?
It should be possible, I think in one of your previous questions I offered a (longer and slower) solution that had a while loop - might be that this can be modified to create a closed polyline from an offset line or whatever using the end points of the new offsets, then join them together.
I'll have a think later to see if I can make something up that works there
Yes that might work thank you for replying and being so active on this!! I have another solution that might be a possible solution as well.
It involves adding a small circle to the end of every polyline/line (0.01m or so). Then when the offset is done it is joined. that circle can then be deleted with the rest of the offsets at the end.
Using imagery this is what I mean
image.png.2d5224126f8167935e2488815de680c0.pngimage.thumb.png.54f95cc4a5ac75c16ae2cc764d3dd802.png
And then you get the boundary like so
Does that make things easier? @Steven P
I see what you are meaning, my thoughts on this are that drawing a line between end points is just as easy (in the offsets, both start ends are next to each other, both end points are the same, so can use (vlax-curve-getStartPoint Obj) and (vlax-curve-getEndPoint OffObj) for these.... should work
Try this
  (defun OffsetJoin ( MyEnt of / acount pt1 pt2 pt3 pt4 MyLines MyOffset)
  (setq MyLines (ssadd))
    (setq VlaOb (vlax-ename->vla-object MyEnt))
    (setq entype (cdr (assoc 0 (cdr (entget MyEnt)))))
    (vla-offset VlaOb of ) ;; offset line 1
    (setq OffObj (vlax-ename->vla-object (entlast)))
    (setq MyLines (ssadd (entlast) MyLines)) ;; add offset to selection set
    (setq pt1 (vlax-curve-getStartPoint OffObj) )
    (setq pt2 (vlax-curve-getEndPoint OffObj) )
    (vla-offset VlaOb (* of -1) ) ;; offset line 2
    (setq pt3 (vlax-curve-getStartPoint OffObj) )
    (setq pt4 (vlax-curve-getEndPoint OffObj) )
    (if (or
          (= (cdr (assoc 0 (cdr (entget MyEnt)))) "CIRCLE") ; Circle
          (= (cdr (assoc 0 (cdr (entget MyEnt)))) "ELLIPSE") ; Ellipse
          (= (cdr (assoc 70 (cdr (entget MyEnt)))) 1) ; closed polyline
      (progn ;Circles, Closed polylines
      ) ; end progn
      (progn ; open entities
        (command "line" pt1 pt3 "")
        (command "line" pt2 pt4 "")
        (command "pedit" "m" (ssname MyLines 0) (ssname MyLines 2) (ssname MyLines 3) (ssname MyLines 1) "" "Y" "J" "" "")
      ) ; end progn
    ) ; end if
  ) ; end defun offsetjoin
        (setq SS1 (ssadd))
		    ) ; endor
  		) ; end defun
  (if (and (setq ss (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*LINE"))))
      ) ;; end and
      (setq undo (not
        (vla-StartUndomark
          (setq doc (vla-get-ActiveDocument (vlax-get-acad-object) ))
      )) ; end not, end setq
;;New Part
      (setq acount 0)
      (while (< acount (sslength ss))
        (offsetjoin (ssname ss acount) of)
        (setq acount (+ acount 1))
      ) ; end while
;; End New Part
;;     (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc))
;;       (mapcar
;;         (function
;;           (lambda ( o )
;;             (vl-catch-all-apply
;;               (function vla-offset) (list obj o)
;;         (list of (- of))
;     (vla-delete ss)
      ) ; end progn
    ) ; end if
  ) ; end while
      (while en
        (ssadd en SS1)
      ) ; end while
  ) ; end if
  ) ; end while
    (entdel ent)
  ) ; end foreach
Just a couple of comments, when you select the white line for offset which end is start ? So the end lines may get drawn on the wrong end. I use a check distance from end points to pick point and then can see whether to join start or ends of new offset.
I use this for -ve (- of) note space between - and of.
An example of check end. once you know start or end then offset matches.
(defun doline ( / d1 d2)
(setq pt1 (vlax-get Obj 'StartPoint))
(setq pt2 (vlax-get Obj 'EndPoint))
(setq d1 (distance pt1 pt3)
	    d2 (distance pt2 pt3)
(if (< d1 d2)
    (setq temp pt1)
    (setq pt1 pt2)
    (setq pt2 temp)
(setq ent (entsel "\npick p/line near end "))
(setq pt3 (cadr ent))
(setq obj (vlax-ename->vla-object (car ent)))
(doline )
Hi @Steven P Thank you for getting on this. I tried it out and it worked very well at closing the lines and doing the offsets. There was one problem that I was finding that it wasn't moving onto the boundary command afterwards. Thank you very much for your help It is very useful to see how this code is written learning a lot.
Can you post a sample drawing of what you tried - it worked for me just now
Yup, good point, in this example though the line is offset both directions and these offset lines will have start end and end end at the same end (?!)
