Chandrakanth Posted November 23, 2022 Posted November 23, 2022 As I am not a great user of AutoCAD and visual lisp on a daily to daily basis, I am looking for help of how to use visual lisp effectively for a smooth work flow at our organization. The following are the points where I need help. 1. To switch on only particular layers of need and leave remaining off. 2. Switching to model space in a layout to access the objects. 3. To explode the objects in a layout. 4. To extract the data of the objects like text, dimension values, content present in the titles and title box in to an excel sheet. Quote
pkenewell Posted November 23, 2022 Posted November 23, 2022 (edited) Hi @Chandrakanth Your topic is very wide, so I'll just start with the #1. There are a couple methods: The first method uses AutoCAD commands and plain AutoLISP to perform the actions. For simplicity this isolate method uses the "ON" and "OFF" for layers since using "FREEZE" has issues with the current active layer and layer "0". Note: Error handling is not included. ;; Method 1 using AutoCAD commands (defun C:ISLM1 (/ i l ll ls oe ss) ;;Mark an Undo (command "._Undo" "_Begin") ; Save the value of CMDECO system var. and turn it off (setq oe (getvar "cmdecho")) (setvar "cmdecho" 0) ; Prompt to select objects (princ "\nSelect objects on Layers to Keep on: ") ; If a Selection set is made. (if (setq ss (ssget)) ; iterate through the selection and get the layer names and add to list "ll". (repeat (sslength ss) (setq l (cdr (assoc 8 (entget (ssname ss (if i i (setq i 0)))))) i (1+ i) ) (if (not (member l ll))(setq ll (cons l ll))) ) ) ; If list ll (layer list) exists, (if ll (progn ; turn all the layers off. Respond "Y" to turning off layer "0" (command "._-layer" "_OFF" "*" "_y" "") ; combine the list of layers into a string separated by commas. (setq ls (apply 'strcat (cons (car ll)(mapcar '(lambda (x)(strcat "," x)) (cdr ll))) ) ) ; Turn back on the selected layers. (command "._-layer" "_ON" ls "") ) ) ; reset the CMDECHO system variable (setvar "cmdecho" oe) ; end the undo mark. (command "_undo" "_End") ; suppress return value (exit quietly) (princ) ) The second method uses ActiveX Visual LISP methods. This has less lines of code and does not require CMDECHO to be turned off. Again using OFF and ON for layers to avoid issues with freezing layer "0" and current active layer. Note: Error handling is not included. (defun C:ISLM2 (/ d i l ll ss) ;; Load Visual LISP functionality (vl-load-com) ; Create an Undo Mark (vla-StartUndoMark (setq d (vla-get-activedocument (vlax-get-acad-object)))) ; Prompt for a selection set (princ "\nSelect objects on Layers to Keep on: ") ; If items are selected, (if (setq ss (ssget)) ; Create a list of layers from the selection set. (repeat (sslength ss) (setq l (cdr (assoc 8 (entget (ssname ss (if i i (setq i 0)))))) i (1+ i) ) (if (not (member l ll))(setq ll (cons l ll))) ) ) ;; If the layer list exists, (if ll ;; Iterate through the layer collection and turn off any layer that does not match the layer list. (vlax-for l (vla-get-layers d) (if (not (member (vla-get-name l) ll))(vla-put-Layeron l :vlax-false)) ) ) ; End the undo mark. (vla-EndUndoMark d) (princ) ) I hope this helps with your first question. If I have time I will circle around to more. Edited November 23, 2022 by pkenewell corrected typos Quote
pkenewell Posted November 23, 2022 Posted November 23, 2022 (edited) @Chandrakanth 7 hours ago, Chandrakanth said: 2. Switching to model space in a layout to access the objects. 3. To explode the objects in a layout. 4. To extract the data of the objects like text, dimension values, content present in the titles and title box in to an excel sheet. Questions for items #2 through 4 #2: You need to explain better what you mean. Are you talking about switching back to to the Model tab, zoomed to the layout window area, or just working in modelspace within the layout viewport? If it is the latter, all you have to do is double-click the left mouse button inside the viewport. #3: I do not know what you mean by "Explode" objects in a viewport. You can't explode objects in a viewport. You can switch to Modelspace and explode objects like blocks and polylines. #4: This is also a huge topic with several different methods depending on what type of items. For example, for Block attributes (whether blocks or Title Blocks), there are already several programs made for this, from express tools ATTIN and ATTOUT, to others made on this site and several other sources. Do a search on this site and you will find something. Here is an Example by a great contributor to this site - @Lee Mac. Edited November 23, 2022 by pkenewell Added example, corrected typos. Quote
BIGAL Posted November 24, 2022 Posted November 24, 2022 (edited) #2 agree use dbl click, or type MS or Mspace. Note Ps or Pspace returns, there are some others as well, if you want to go to "Model" layout can do a shortcut (setvar 'ctab "Model") I have also a GOTO which does as it implies goes to a layout via enter a number, Model is 0. #4 yes can be done and send direct to excel. Like wise do a google lots of times requested. Edited November 24, 2022 by BIGAL Quote
Chandrakanth Posted November 24, 2022 Author Posted November 24, 2022 12 hours ago, pkenewell said: Hi @Chandrakanth Your topic is very wide, so I'll just start with the #1. There are a couple methods: The first method uses AutoCAD commands and plain AutoLISP to perform the actions. For simplicity this isolate method uses the "ON" and "OFF" for layers since using "FREEZE" has issues with the current active layer and layer "0". Note: Error handling is not included. ;; Method 1 using AutoCAD commands (defun C:ISLM1 (/ i l ll ls oe ss) ;;Mark an Undo (command "._Undo" "_Begin") ; Save the value of CMDECO system var. and turn it off (setq oe (getvar "cmdecho")) (setvar "cmdecho" 0) ; Prompt to select objects (princ "\nSelect objects on Layers to Keep on: ") ; If a Selection set is made. (if (setq ss (ssget)) ; iterate through the selection and get the layer names and add to list "ll". (repeat (sslength ss) (setq l (cdr (assoc 8 (entget (ssname ss (if i i (setq i 0)))))) i (1+ i) ) (if (not (member l ll))(setq ll (cons l ll))) ) ) ; If list ll (layer list) exists, (if ll (progn ; turn all the layers off. Respond "Y" to turning off layer "0" (command "._-layer" "_OFF" "*" "_y" "") ; combine the list of layers into a string separated by commas. (setq ls (apply 'strcat (cons (car ll)(mapcar '(lambda (x)(strcat "," x)) (cdr ll))) ) ) ; Turn back on the selected layers. (command "._-layer" "_ON" ls "") ) ) ; reset the CMDECHO system variable (setvar "cmdecho" oe) ; end the undo mark. (command "_undo" "_End") ; suppress return value (exit quietly) (princ) ) The second method uses ActiveX Visual LISP methods. This has less lines of code and does not require CMDECHO to be turned off. Again using OFF and ON for layers to avoid issues with freezing layer "0" and current active layer. Note: Error handling is not included. (defun C:ISLM2 (/ d i l ll ss) ;; Load Visual LISP functionality (vl-load-com) ; Create an Undo Mark (vla-StartUndoMark (setq d (vla-get-activedocument (vlax-get-acad-object)))) ; Prompt for a selection set (princ "\nSelect objects on Layers to Keep on: ") ; If items are selected, (if (setq ss (ssget)) ; Create a list of layers from the selection set. (repeat (sslength ss) (setq l (cdr (assoc 8 (entget (ssname ss (if i i (setq i 0)))))) i (1+ i) ) (if (not (member l ll))(setq ll (cons l ll))) ) ) ;; If the layer list exists, (if ll ;; Iterate through the layer collection and turn off any layer that does not match the layer list. (vlax-for l (vla-get-layers d) (if (not (member (vla-get-name l) ll))(vla-put-Layeron l :vlax-false)) ) ) ; End the undo mark. (vla-EndUndoMark d) (princ) ) I hope this helps with your first question. If I have time I will circle around to more. @pkenewell Firstly Thank You so much for responding and helping. I am trying to use lisp in a way that I can switch on the particular layer/layers by calling the layer's name in the command and not using the mouse to go and select the particular layer. Quote
Chandrakanth Posted November 24, 2022 Author Posted November 24, 2022 11 hours ago, pkenewell said: @Chandrakanth Questions for items #2 through 4 #2: You need to explain better what you mean. Are you talking about switching back to to the Model tab, zoomed to the layout window area, or just working in modelspace within the layout viewport? If it is the latter, all you have to do is double-click the left mouse button inside the viewport. #3: I do not know what you mean by "Explode" objects in a viewport. You can't explode objects in a viewport. You can switch to Modelspace and explode objects like blocks and polylines. #4: This is also a huge topic with several different methods depending on what type of items. For example, for Block attributes (whether blocks or Title Blocks), there are already several programs made for this, from express tools ATTIN and ATTOUT, to others made on this site and several other sources. Do a search on this site and you will find something. Here is an Example by a great contributor to this site - @Lee Mac. For #2: I am looking for the latter the double click to shift to model space with in the view port. I basically do not want to double click and want to know if there is a way by using lisp if I can give a command to switch to the model space and I THINK MSpace(MS) does the job as someone have suggested me in this thread. For #3: I mean explode objects in a model spacce (my bad sorry). So to explode I need to drag the mouse and select the objects. I am looking for a way if there is something that I can use to explode the objects by giving a direct command or using lisp. For #4: I will surely look in to the site of @LeeMac and try to find a way. Quote
Chandrakanth Posted November 24, 2022 Author Posted November 24, 2022 1 hour ago, BIGAL said: #2 agree use dbl click, or type MS or Mspace. Note Ps or Pspace returns, there are some others as well, if you want to go to "Model" layout can do a shortcut (setvar 'ctab "Model") I have also a GOTO which does as it implies goes to a layout via enter a number, Model is 0. #4 yes can be done and send direct to excel. Like wise do a google lots of times requested. @Thank You @BIGAL for responding and helping. I have used your Mspace suggestion and that is what exactly I am looking for. Also can You help me if there is some command or lisp that I can use to explode the objects in the model space without selecting the objects with the help of mouse. Quote
Chandrakanth Posted November 24, 2022 Author Posted November 24, 2022 13 hours ago, pkenewell said: Hi @Chandrakanth Your topic is very wide, so I'll just start with the #1. There are a couple methods: The first method uses AutoCAD commands and plain AutoLISP to perform the actions. For simplicity this isolate method uses the "ON" and "OFF" for layers since using "FREEZE" has issues with the current active layer and layer "0". Note: Error handling is not included. ;; Method 1 using AutoCAD commands (defun C:ISLM1 (/ i l ll ls oe ss) ;;Mark an Undo (command "._Undo" "_Begin") ; Save the value of CMDECO system var. and turn it off (setq oe (getvar "cmdecho")) (setvar "cmdecho" 0) ; Prompt to select objects (princ "\nSelect objects on Layers to Keep on: ") ; If a Selection set is made. (if (setq ss (ssget)) ; iterate through the selection and get the layer names and add to list "ll". (repeat (sslength ss) (setq l (cdr (assoc 8 (entget (ssname ss (if i i (setq i 0)))))) i (1+ i) ) (if (not (member l ll))(setq ll (cons l ll))) ) ) ; If list ll (layer list) exists, (if ll (progn ; turn all the layers off. Respond "Y" to turning off layer "0" (command "._-layer" "_OFF" "*" "_y" "") ; combine the list of layers into a string separated by commas. (setq ls (apply 'strcat (cons (car ll)(mapcar '(lambda (x)(strcat "," x)) (cdr ll))) ) ) ; Turn back on the selected layers. (command "._-layer" "_ON" ls "") ) ) ; reset the CMDECHO system variable (setvar "cmdecho" oe) ; end the undo mark. (command "_undo" "_End") ; suppress return value (exit quietly) (princ) ) The second method uses ActiveX Visual LISP methods. This has less lines of code and does not require CMDECHO to be turned off. Again using OFF and ON for layers to avoid issues with freezing layer "0" and current active layer. Note: Error handling is not included. (defun C:ISLM2 (/ d i l ll ss) ;; Load Visual LISP functionality (vl-load-com) ; Create an Undo Mark (vla-StartUndoMark (setq d (vla-get-activedocument (vlax-get-acad-object)))) ; Prompt for a selection set (princ "\nSelect objects on Layers to Keep on: ") ; If items are selected, (if (setq ss (ssget)) ; Create a list of layers from the selection set. (repeat (sslength ss) (setq l (cdr (assoc 8 (entget (ssname ss (if i i (setq i 0)))))) i (1+ i) ) (if (not (member l ll))(setq ll (cons l ll))) ) ) ;; If the layer list exists, (if ll ;; Iterate through the layer collection and turn off any layer that does not match the layer list. (vlax-for l (vla-get-layers d) (if (not (member (vla-get-name l) ll))(vla-put-Layeron l :vlax-false)) ) ) ; End the undo mark. (vla-EndUndoMark d) (princ) ) I hope this helps with your first question. If I have time I will circle around to more. @pkenewellThank You for the code really appreciate that. I am exactly looking for something like this. I wanted to have the layers (TEXT,DIMENSIONS,TITLE,TITLE BLOCK) on in my drawing and rest of the layers off. I wanted to do that by typing a command and not by selecting the objects with the mouse. 1 Quote
Chandrakanth Posted November 24, 2022 Author Posted November 24, 2022 I have figured out how to get the first three points that I have asked. I wanted to know how could I extract the data from a particular layout without using the mouse drag to select all the objects. Quote
Steven P Posted November 24, 2022 Posted November 24, 2022 5 hours ago, Chandrakanth said: I have figured out how to get the first three points that I have asked. I wanted to know how could I extract the data from a particular layout without using the mouse drag to select all the objects. In a LISP to select al the objects on a layer, use ssget "X" - see this link here http://lee-mac.com/ssget.html Lee Macs MacAtt is a good routine to extract title data - but for the rest we might need a little more for exactly what data to extract (for example, a text might have the text itself, a layer it is written on, its location, height, font and so on). The list of entities given by (ssget ) can be a starting point. Use the assoc command with (entget (ssname 'selection set' 'position') ) to take the data you need, save to a list and then at the end of the routine write all that to excel - loads of examples out there but to help we might need some information what you want the output to be. Quote
BIGAL Posted November 25, 2022 Posted November 25, 2022 Ok in lisp you can make very simple defuns that use CAD commands so for layers on/off you need to look at the "-layer" command note the "-" in front of layer. This turns off the dialouge layers method and asks for manual input. If you type -layer this appears lots of options ok so the sequence is s TEXT OFF * Y ON TEXT,DIMENSIONS,TITLE,TITLE BLOCK in Lisp (defun c:mylay ( / ) (command "-layer" "S" "TEXT" "OFF" "*" "" "ON" "DIMENSIONS,TITLE,TITLE BLOCK" "") ) Do you know how to autoload a lisp program on start up ? Quote
Chandrakanth Posted November 25, 2022 Author Posted November 25, 2022 12 hours ago, Steven P said: In a LISP to select al the objects on a layer, use ssget "X" - see this link here http://lee-mac.com/ssget.html Lee Macs MacAtt is a good routine to extract title data - but for the rest we might need a little more for exactly what data to extract (for example, a text might have the text itself, a layer it is written on, its location, height, font and so on). The list of entities given by (ssget ) can be a starting point. Use the assoc command with (entget (ssname 'selection set' 'position') ) to take the data you need, save to a list and then at the end of the routine write all that to excel - loads of examples out there but to help we might need some information what you want the output to be. Thank You @Steven P for responding. Let me run through the steps of what exactly I need so that You have a clarity. I have the required layers ON in my drawing layout of which I need to extract the data. Now if it is in a normal case I would just type in data extraction and follow all those steps the wizard asks me to. But I do not want to do that. Instead I want to extract the data with a single command and the data should be extracted from the present layout I am working on containing all the objects, content/value of the object(for example dimension value in case if the object is dimension etc.,), their x,y and z positions. Please do respond if You want to understand more about the case. Thank You once again for reaching out and helping. Quote
Chandrakanth Posted November 25, 2022 Author Posted November 25, 2022 2 hours ago, BIGAL said: Ok in lisp you can make very simple defuns that use CAD commands so for layers on/off you need to look at the "-layer" command note the "-" in front of layer. This turns off the dialouge layers method and asks for manual input. If you type -layer this appears lots of options ok so the sequence is s TEXT OFF * Y ON TEXT,DIMENSIONS,TITLE,TITLE BLOCK in Lisp (defun c:mylay ( / ) (command "-layer" "S" "TEXT" "OFF" "*" "" "ON" "DIMENSIONS,TITLE,TITLE BLOCK" "") ) Do you know how to autoload a lisp program on start up ? yeah @BIGAL figured how I can use the -layer command to switch on and off multiple or all layers at a time and then for switching between the model space and the paper space using the MS and PS. and then used the explode selecting all objects to separate the objects I need. Now I am trying to figure out how I can extract the data from a particular layout having all the data of the objects included. Usually I just do the DX and then follow the steps the data extraction wizard asks me to. But I wanted to do that using a single command or very few steps possible where I would not use the mouse clicking. Thank You for the response. Get back to me If You have anything with this data extraction. Quote
Chandrakanth Posted November 25, 2022 Author Posted November 25, 2022 4 hours ago, BIGAL said: Ok in lisp you can make very simple defuns that use CAD commands so for layers on/off you need to look at the "-layer" command note the "-" in front of layer. This turns off the dialouge layers method and asks for manual input. If you type -layer this appears lots of options ok so the sequence is s TEXT OFF * Y ON TEXT,DIMENSIONS,TITLE,TITLE BLOCK in Lisp (defun c:mylay ( / ) (command "-layer" "S" "TEXT" "OFF" "*" "" "ON" "DIMENSIONS,TITLE,TITLE BLOCK" "") ) Do you know how to autoload a lisp program on start up ? @Bigal Actually I do not know anything about lisp. As part of a project that we are are working on with a construction company have to use autocad to make the workflow smooth. So the data extraction is the last step as part of it. So I am trying to figure out a way extracting the data with a single command or minimum steps involved. Quote
Steven P Posted November 25, 2022 Posted November 25, 2022 Looking at this, do you have a dataextraction template set up to your requirements? You can run -dataextraction which runs the command through the command line rather than through a dialogue box and so it can be run through a LISP Maybe try that, in LISP maybe (command "-dataextraction" filepath "Yes") Quote
Chandrakanth Posted November 28, 2022 Author Posted November 28, 2022 On 11/25/2022 at 3:09 PM, Steven P said: Looking at this, do you have a dataextraction template set up to your requirements? You can run -dataextraction which runs the command through the command line rather than through a dialogue box and so it can be run through a LISP Maybe try that, in LISP maybe (command "-dataextraction" filepath "Yes") @Steven P May I know what exactly do you mean by dataextraction template. Because I have not worked on that medhod till now. Is that something I prepare and extract the data using that template. If You can Can You please elaborate for me how I should be doing this. Quote
BIGAL Posted November 28, 2022 Posted November 28, 2022 Doing a layout only extraction complicates things a bit. You can select the viewport and then in turn select objects in Model space. I found dataextraction does not redo the window select so objects added are not included in the saved dxe. So you may need a custom extract. To do it really do need to know about this below, need a sample dwg. "4. To extract the data of the objects like text, dimension values, content present in the titles and title box in to an excel sheet." Do a dataextraction on a sample layout and save to a table then can see all the options per type of object that you want. Quote
