Persistent Click Dimension
Abrasive
Trying to make a routine where my dimension command stays persistent.
I feel like this should be basic but .....I can't get it😔
;PCD forPersistent Click Dimension
(defun c:PCD ( )
(command "_.Dimaligned" "_E")
  (while (= (getvar "CmdActive") 0)
    (command "" "_.Dimaligned" "_E")
What I would like to do is just single click entities without  starting the command over and when I'm done hit Esc to end the command....
I hope that makes sense?
I think the problem is your 'command "_.dimaligned" .....)
If you work through the command manually - always a good way to go - it asks for 3 inputs after the command (end A, end B and extension), you'll need to add a "pause" to allow for user input (see below).
Not sure about the while loop - would an escape escape from the full lISP or just the command - not so important with this but for others if you want to do something after it might be worth checking that
(defun c:PCD ( )
 (command "_.Dimaligned" pause pause pause)
(defun c:PCD ( )
pause!!!
Thank you, that worked....
