ChybaKpisz Posted November 3, 2022 Share Posted November 3, 2022 (edited) I want to make selection and add vertices at midpoints (red crosses) for all segments inside of selection box. Or in other words - divide all single-segmented parts of polyline inside of selection to 2-segmented. I was looking for this specific routine but did't find it. Edited November 3, 2022 by ChybaKpisz Quote Link to comment Share on other sites More sharing options...
Tsuky Posted November 4, 2022 Share Posted November 4, 2022 Perhaps this? (vl-load-com) (defun add_vtx (obj add_pt ent_name / bulg) (vla-addVertex obj (1+ (fix add_pt)) (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbdouble (cons 0 1)) (list (car (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name)) (cadr (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name)) ) ) ) ) (setq bulg (vla-GetBulge obj (fix add_pt))) (vla-SetBulge obj (fix add_pt) (/ (sin (/ (* 4 (atan bulg) (- add_pt (fix add_pt))) 4)) (cos (/ (* 4 (atan bulg) (- add_pt (fix add_pt))) 4)) ) ) (vla-SetBulge obj (1+ (fix add_pt)) (/ (sin (/ (* 4 (atan bulg) (- (1+ (fix add_pt)) add_pt)) 4)) (cos (/ (* 4 (atan bulg) (- (1+ (fix add_pt)) add_pt)) 4)) ) ) (vla-update obj) ) (defun c:AddVtx@tMid ( / pt1 pt2 js AcDoc Space pt_l min_x max_x min_y max_y n ename obj prm pt pt_n-1) (initget 1) (setq pt1 (getpoint "\nPick corner first point: ")) (initget 33) (setq pt2 (getcorner pt1 "\nPick corner opposite: ")) (princ "\nSelect polylines.") (setq js (ssget "_C" pt1 pt2 '((0 . "LWPOLYLINE")))) (cond (js (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) pt_l (list pt1 pt2) min_x (apply 'min (mapcar 'car pt_l)) max_x (apply 'max (mapcar 'car pt_l)) min_y (apply 'min (mapcar 'cadr pt_l)) max_y (apply 'max (mapcar 'cadr pt_l)) ) (vla-startundomark AcDoc) (repeat (setq n (sslength js)) (setq ename (ssname js (setq n (1- n))) obj (vlax-ename->vla-object ename) prm (vlax-curve-getEndParam obj) ) (repeat (fix prm) (setq pt (trans (vlax-curve-getPointAtParam obj prm) 0 1) pt_n-1 (trans (vlax-curve-getPointAtParam obj (1- prm)) 0 1) ) (cond ((and (> (car pt) min_x) (< (car pt) max_x) (> (cadr pt) min_y) (< (cadr pt) max_y) (> (car pt_n-1) min_x) (< (car pt_n-1) max_x) (> (cadr pt_n-1) min_y) (< (cadr pt_n-1) max_y) ) (setq prm (- prm 0.5)) (add_vtx obj prm ename) (setq prm (- prm 0.5)) ) (T (setq prm (1- prm))) ) ) ) (vla-endundomark AcDoc) (sssetfirst nil js) ) ) (prin1) ) 1 1 Quote Link to comment Share on other sites More sharing options...
ChybaKpisz Posted November 4, 2022 Author Share Posted November 4, 2022 YES! That's exactly what I need. Thank you so much. Quote Link to comment Share on other sites More sharing options...
