Select objects in all layer if ........
reza
HI Everyone
How to select the polylines whose color is by layer.
If that only objects whose layer color is set to white are selected.
Select Bylayer.dwg
Edited by reza
This handy reference http://lee-mac.com/ssget.html and look at 'ALL' changing his example (0 . "LINE") to be colour ( 62 . "Colour" ) and colour 256 is 'ByLayer' giving you something like
(setq ss (ssget "_A" '((0 . "LWPOLYLINE")(62 . 256))) )
will select all polylines that are 'by layer' colour and create a selection set with them  for you to do what you want after
  • Like 2
Dear Steven
Thx for reply
Okey : we selected all lwpolylines are color by layer
and then :
I want only selection lwpolylines that are white in color.
But how can I select them when their color is by layer
That is a little more involved.
(defun C:FOO (/ SS layers lay x lst SS1)
  (setq SS (ssadd)) ;emty selecton set to add entity's to
  (setq layers (Table "layer"))
  (foreach lay layers
    (setq x (entget (tblobjname "layer" lay)))
    (if (eq (cdr (assoc 62 x)) 7)
      (setq lst (cons lay lst)) ;add each layer that has color white to a new list
  (foreach lay lst
    (if (setq SS1 (ssget "_X" (list '(0 . "*POLYLINE") (cons 8 lay) '(62 . 256) (cons 410 (getvar 'ctab))))) ;process that 2nd list of layers to see if any
      (setq SS (acet-ss-union (list SS SS1)))        ;polylines are bylayer and add them to ss
    (setq SS1 nil) ; reset so things arn't added twice
  (if (setq SS1 (ssget "_X" (list '(0 . "LWPOLYLINE") '(62 . 7) (cons 410 (getvar 'ctab))))) ;alos find any polylines that are white
    (setq SS (acet-ss-union (list SS SS1))) ;and add them to SS
  (sssetfirst nil SS)
;Written By Michael Puckett
(defun Table (s / d r)
  (while (setq d (tblnext s (null d)))
    (setq r (cons (cdr (assoc 2 d)) r))
  • Like 3
  • Agree 1
Am sure I saw this the other day!... (haven't needed to use it yet myself though)
I am pretty sure if you want color set to bylayer make a selection set ss. Look at each item and check against its LAYER COLOR can ssadd etc and is white then. A 2 step process. May not be super fast.
Otherwise get all Layers look at each layer color is it "white" then do ( ssget "X"  (list (0 . "*POLYLINE") "(cons 8 layername) (62 . 256))) and ssadd to result repeating for all layers.
Thank you all.🙏🙏
The code written by mhupp 🙏🙏 solved my problem.
