CyberAngel Posted October 28, 2022 Share Posted October 28, 2022 (edited) I created a sheet set. Later, I copied one of the layouts to create a similar sheet, then copied that one for another similar sheet. When I attempt to import those two layouts into my sheet set, it says the first copy is "already part of a sheet set"--but the other one is okay to import. Error on my part? Bug? or feature? What probably made it balk is that I made the copy but mistakenly changed the original. So I swapped the layout names and went on my merry way. It looks like the only solution is to delete the sheet set and create a new one. Any other suggestions? Remove the offending sheets and bring them back in? Edit: I removed all three sheets from my sheet set and imported them back in. Problem solved. Edited October 28, 2022 by CyberAngel Quote Link to comment Share on other sites More sharing options...
