Hi all,
I got 2 criteria of selection wich i wanna use to make 1 selectionset...
I want all blocks of a predefined layername and blockname list
I want all line,arc and polyline of a predefinied layername list...
Can this be written in 1 ssget function?
If not... how to easily combine both?
thanks in advance.
(setq ssvalid (ssget "_X" (list (cons 0 "INSERT" (cons 8 validlisttotal) (cons 2 validlisttotalblocks))))
(setq ssvalid (ssget "_X" (list (cons 0 "LINE,ARC,LWPOLYLINE" (cons 8 validlisttotal))))
Maybe this will help, http://lee-mac.com/ssget.html, looking towards the bottom and the 'or' option, you want to select entities that are blocks OR lines (use the description in the AND box above for a good example, changing it to OR of course)
If your code is working nicely though a bit long, not changing anything that works (always good...) this  https://www.afralisp.net/autolisp/tutorials/selection-sets.php has a description of how to add 2 existing selection sets together (about 2/3 of the way down the page, creating a 'union' between selection sets). Not sure what happens if an entity is in both sets, probably will exist twice in the new selection set and be processed twice subsequently.
  • Agree 1
Best to use the Logical Operators shown in lee mac's website to create one selection set like Steven says.
While afralisp also works I don't like to use counters so here is the foreach way.
(setq SS (ssget "_X" (list (cons 0 "INSERT") (cons 8 validlisttotal) (cons 2 validlisttotalblocks)))) ;was missing ) on (cons 0 INSERT
(setq SS1 (ssget "_X" (list (cons 0 "LINE,ARC,LWPOLYLINE") (cons 8 validlisttotal)))) ;use a diffrent selection set name
(foreach ent (mapcar 'cadr (ssnamex SS1)) ;builds a list of entity names from selection set ss1
  (ssadd ent ss) ;adds each entity from ss1 to ss
Thanks for the suggestions, i think i found a simple one...
	(setq ssvalid1 (ssget "_X" (list (cons 0 "INSERT") (cons 8 validlisttotal) (cons 2 validlisttotalblocks))))
	(setq ssvalid2 (ssget "_X" (list (cons 0 "LINE,ARC,LWPOLYLINE") (cons 8 validlisttotal))))
	(setq ssvalid (acet-ss-union (list ssvalid1 ssvalid2)))
Works like a charm! :D
  • Like 2
Nice learning something every day!
Edited by mhupp
3 hours ago, Aftertouch said:
Hi all,
thanks in advance.
Nothing will work with your examples because they are invalid to begin with.
Try this untested:
(ssget "_X"
       (list '(-4 . "<OR")
	     '(-4 . "<AND")
	     '(0 . "INSERT")
	     '(-4 . "AND>")
	     '(-4 . "<AND")
	     '(0 . "LINE,ARC,LWPOLYLINE")
	     '(-4 . "AND>")
	     '(-4 . "OR>")
