Frederick Posted October 27, 2022 Share Posted October 27, 2022 Hello guys, I wanna move block by editing properties: Position X, Position Y, Position Z and angle. And iam using vla function: (this should move block wich i selected to the point Point have format (0,0,0) (setq object (vlax-ename->vla-object (ssname ss 0))) ;selected block (vla-put-coordinates object (vlax-3d-point point));change coordinates of the block to 0,0,0 Any idea? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted October 28, 2022 Share Posted October 28, 2022 Here is an example for you to learn from although doing it with DXF is much simpler and faster. (defun c:test ( / s o ) (and (setq s (car (entsel "\nSelect block to move to 0,0,0 : "))) (or (= (cdr (assoc 0 (entget s))) "INSERT") (alert "Invalid object selected !") ) (setq o (vlax-ename->vla-object s)) (or (vla-put-insertionpoint o (vlax-3d-point '(0. 0. 0.))) (vla-put-rotation o (* pi 0.25)) ;; rotation angle = 45 Deg. ) ) (princ) ) (vl-load-com) 3 Quote Link to comment Share on other sites More sharing options...
Frederick Posted October 28, 2022 Author Share Posted October 28, 2022 Thank you! Quote Link to comment Share on other sites More sharing options...
Tharwat Posted October 28, 2022 Share Posted October 28, 2022 You're welcome. Quote Link to comment Share on other sites More sharing options...
