Hi!
I have this code that i found here in the forum it was created by @rlx.
My question is how to add an automatic current date and time to the end of the file when im saving it.
Many thanks! xoxo
(defun c:foo (/ _dir F NF P SF SH)
 (defun _dir (msg path / sh folder out)
   (or (vl-file-directory-p path) (setq path (getvar 'dwgprefix)))
   (cond ((and  (setq sh (vlax-get-or-create-object "Shell.Application"))
  (setq folder (vlax-invoke-method sh 'browseforfolder 0 msg "&H2000" path))
   (setq out (vlax-get-property (vlax-get-property folder 'self) 'path))
   (setq out (strcat (vl-string-right-trim "\\" out) "\\"))
   (and sh (vlax-release-object sh))
   out
 (if (setq p (_dir "Pick a directory yo!" "E:\\Autocad Files\\SSC\\North Region\\SNE\\"))
     (setq f (getvar 'dwgname))
     (setq sf "Plans")
     (setq nf (strcat p sf "\\" f))
     (cond
((cond
   ((findfile nf) (print "File exists...") nil)
   ((vl-file-directory-p (strcat p sf)) (vl-file-copy (strcat (getvar 'dwgprefix) f) nf) t)
   ((vl-mkdir (strcat p sf)) (vl-file-copy (strcat (getvar 'dwgprefix) f) nf) t)
 (vlax-invoke-method sh 'open nf)
(vl-load-com)
This is what I use
(menucmd "M=$(edtime, $(getvar,date),DD-MO-YYYY - HH:MM:SS AM/PM)")
--edit
For file name replaced the / with -  in the date so it won't error
Edited by mhupp
I have a field %<\AcVar SaveDate \f "M/d/yyyy">% with Date all my drawing are saved in all my title blocks.
While I've never added the date to a file name I'd probably keep it as short as possible if I had to. The 20 in 2022 shouldn't matter for anyone doing cad now in their lifetime so I'd cut that off as well.
Same here 👍
With a bit more info:
"File: %<\\AcVar Filename \\f \"%tc3%fn7\">% printed by %<\\AcVar Login>% on %<\\AcVar PlotDate \\f \"M/d/yyyy h:mm:ss tt\">% using AutoCAD Version: %<\\AcVar acadver>%"
Edited by ronjonp
@mhupp No need for AM/PM, the results are returned in military time.
Thanks!
I am very new to LISP can someone help me where to put the "(menucmd "M=$(edtime, $(getvar,date),DD-MO-YYYY - HH:MM:SS AM/PM)")"?
Do i need to assign it to a variable and then strcat them or how?
THANKS
2 hours ago, donat768 said:
Thanks!
THANKS
UPDATE LINE
TO
(setq nf (strcat p sf "\\" (menucmd "M=$(edtime, $(getvar,date),DD-MO-YYYY - HH:MM:SS AM/PM)") "-" f))
