Macro to Export text from eDRAWINGS to excel
tiwari1211
Dear Experts,
I hope you are doing well.
I am looking for a way to export the text from the DXF file to Excel. I have an Excel macro that worked fine when I had the DXF file open in AutoCAD, but now I don't have AutoCAD. I use eDRAWINGS to open the DXF files. Can anyone help me to have a program/Macro which export text from eDrawings to Excel ?
If required i can share the Excel macro.
This will be a great help to me. Thanks a lot for your reply.
I think simple answer is "NO", eDrawings appears to be a viewer so no programming interface, you need say a Bricscad or another clone if you don't want to go down the Autocad path, do not buy LT no excel link.
If you can write a VBA macro in excel then you can do what you want, a dxf file is just a text file so can look for MTEXT and read the lines below for layer and textstring. Just open in Word and have a look. In below the textstring is "Heading" look for Mtext then 1 then next line. NOTE lots of spaces in the lines.
MTEXT
  5
40
330
1D
100
AcDbEntity
  8
TEXT
100
AcDbMText
 10
796.131475
 20
18.866797
 30
0.0
 40
18.0
 41
797.031475
 46
25.366797
 71
     3
 72
     5
  1
HEADING
Edited by BIGAL
