if (item of member of list) is equal 0.0 (remove member)
reza
HI everyone
I have this list:ย ((0.0 70.8187) (0.0 -119.977) (61.875 44.4858)) orย ((88.21 0.0) (19.80ย 0.0) (61.875 44.4858))
I want remove all member if x=0 or y=0 then remove members of list==> ((61.875 44.4858))
With that I want to remove, you pretty much don't need computer or state of mind...
dear marko:
It is possible to say what you mean more clearly.
Unfortunately, I did not understand what you mean.
(defun foo (lst)
    (vl-remove-if '(lambda (x) (or (zerop (car x)) (zerop (cadr x)))) lst)
ย
  • Thanks 1
Hi Jonathan Handojo:
thx for reply
I used your advice and my problem was solved.
thanks again.
Given that we're working with reals, I would suggest the use of the equal function with an appropriate tolerance - I would reserve zerop for when testing integer values.
ย
Hence:
(vl-remove-if '(lambda ( x ) (or (equal (car x) 0.0 1e-8) (equal (cadr x) 0.0 1e-8))) lst)
ย
Or, for any coordinate:
(vl-remove-if '(lambda ( x ) (vl-some '(lambda ( y ) (equal y 0.0 1e-8)) x)) lst)
ย
  • Like 2
  • Thanks 1
3 hours ago, reza said:
Dear Jonathan:
๐Ÿ™๐Ÿ™๐Ÿ™
thanks a lot again.
No worries. Glad to help.
However, I do agree with what Lee mentioned. His function should be slightly more bulletproof than mine.
HI Everyone:
Thx Lee Mac for reply and attentionย ๐Ÿ™๐Ÿ™
Thxย Jonathanย ๐Ÿ™๐Ÿ™
  • 1 month later...
Deleted
Edited by troggarf
Dear troggarf:
I'm sorry that I paid attention to your reply so late.
I have used the advice of experts like you and dear Marko many times in different forums.
I think it's my fault that I bore Marco with very simple questions.
๐Ÿ™๐Ÿ™๐Ÿ™
