REMOVE / DELETE VERTEX FROM 3D POLYLINES ON POINTS OF A DEFINED LAYER
CADWORKER
Hi All,
I have a drawing with lot of 3polylines and these polylines are connected to points on different layers.
Now I have to remover vertices from some layers. All I am doing is selecting the 3dpolylines and remove vertex.
Is there any way to remove the all the vertices on these layers at once.
Thanks in advance
You could look for a point at each vertice and see what layer it is, the only question is the 1st point always the correct layer ? You could possibly use (ssget pt '((0 . "POINT"))) for each vertice.
Post a dwg.
Post a dwg.
TEST-3D-POLY-01.dwg
