rcb007 Posted October 18, 2022 Posted October 18, 2022 (edited) I am having a hard time trying to get selected blocks from AutoCAD into excel. I am wanting it to write each block by name on each row that is selected. The routine does work, which will interface with Autocad to allow me to select the blocks, but as for take the selection and writing the number of selected blocks in excel. Any ideas? Sub PickBlocksAndGetData() 'for Excel sheet managing purposes Dim MySht As Worksheet Dim MyCell As Range 'for Autocad application managing purposes Dim ACAD As AcadApplication Dim ThisDrawing As AcadDocument Dim Block As AcadBlock ' for selection set purposes Dim ssetObj As AcadSelectionSet Dim gpCode(0) As Integer Dim dataValue(0) As Variant 'for general variables managing purposes Dim iRow As Long Dim BlockName As Double ' Autocad Session handling On Error Resume Next Set ACAD = GetObject(, "AutoCAD.Application") On Error GoTo 0 If ACAD Is Nothing Then Set ACAD = New AcadApplication ACAD.Visible = True End If Set ThisDrawing = ACAD.ActiveDocument ' selecting Blocks on screen by selelection set filtering method On Error Resume Next Set ssetObj = ThisDrawing.SelectionSets.Item("BlockSSET") If Err Then Set ssetObj = ThisDrawing.SelectionSets.Add("BlockSSET") On Error GoTo 0 ssetObj.Clear 'setting filtering critera gpCode(0) = 0 dataValue(0) = "Insert" 'selecting Blocks ssetObj.SelectOnScreen gpCode, dataValue ' processing Blocks If ssetObj.Count > 0 Then ' writing sheet headings Set MySht = ActiveSheet Set MyCell = MySht.Cells(1, 1) With MyCell .Offset(0, 0).Value = "Block Name" End With 'clearing previous written data iRow = MySht.Cells(MySht.Rows.Count, 1).End(xlUp).Row If iRow > 1 Then MyCell.Offset(1, 0).Resize(iRow - 1, 3).Clear 'retrieving Block Name and writing them on worksheet iRow = 1 For Each Block In ssetObj 'retrieving Block Name With Block BlockName = .Name End With ' writing Block Name With MyCell .Offset(iRow, 0).Value = "Block Name" & iRow End With iRow = iRow + 1 Next Block End If ' cleaning up before ending ssetObj.Delete Set ssetObj = Nothing Set ThisDrawing = Nothing Set ACAD = Nothing End Sub Thank you for any help! Edited October 18, 2022 by rcb007 Quote
BIGAL Posted October 19, 2022 Posted October 19, 2022 As your running a excel macro did you google for help it should be out there maybe not 100% but a start. Do you have to run in excel as Autocad can open and populate excel direct, like your code. For me VBA or LIsp make a selection set, sort by block name, count block names into a new list, run make rows of the list. That is a few things missing in your code. Need to make a array in VBA maybe. There is heaps of "count blocks to CSV lisp or vba" Google. https://myengineeringworld.net/2014/02/count-blocks-autocad-vba.html#:~:text=How to use it 1 Open AutoCAD. 2,will appear (see the figure above). More items Quote
rcb007 Posted October 19, 2022 Author Posted October 19, 2022 Thanks for the guidance BIGAL, I have an excel worksheet which I want to import the selected blocks. Then the worksheet counts and sort by the block names to generate the results I need. I have played around with some that are lisp driven, like Blocks2Excel, but with that setup it creates a new csv. Quote
BIGAL Posted October 20, 2022 Posted October 20, 2022 I have stopped doing import csv and do direct to excel. There is a program getexcel.lsp which is a great place to start, which is what I did adding/changing a few functions. the latest is select rows of text and they appear as rows in excel. There is lots of code examples by Fixo unfortunately he is no longer with us. Just a comment i have gone deeper with counting blocks with up to 5 attributes deep used in determining common blocks the blocks can have 0 or tested on blocks with 20 attributes a mixture of blocks. Reult goes to a table but then I have read table export to excel also. Quote
rcb007 Posted October 20, 2022 Author Posted October 20, 2022 (edited) Thank you for sharing. I was able to make alittle progress. I have stumbled on this code below from here. https://forums.autodesk.com/t5/vba/extract-attributes-by-specific-block-name/td-p/9047161 Option Explicit Sub Extract() 'for Autocad application managing purposes Dim ACAD As AcadApplication Dim ThisDrawing As AcadDocument Dim Block As AcadBlock Dim MySelection As AcadSelectionSet ' Autocad Session handling On Error Resume Next Set ACAD = GetObject(, "AutoCAD.Application") On Error GoTo 0 If ACAD Is Nothing Then Set ACAD = New AcadApplication ACAD.Visible = True End If Set ThisDrawing = ACAD.ActiveDocument If ThisDrawing Is Nothing Then MsgBox "Please open a drawing file and then restart this macro." Exit Sub End If '------------------------------------------------------- 'Excel setup Dim Excel As Application Dim MySheet As Excel.Worksheet Dim BlckNameRng As Excel.Range, TagsRng As Excel.Range, myCell As Excel.Range Dim iniColStr As String Dim iniRow As Long, iniCol As Long ' handling excel application On Error Resume Next Set Excel = GetObject(, "Excel.Application") If Err Then Set Excel = CreateObject("Excel.Application") ' handling workbook and worksheet With Excel .Visible = True Set MySheet = .ActiveWorkbook.ActiveSheet If Err Then .Workbooks.Add Set MySheet = .ActiveWorkbook.ActiveSheet End If On Error GoTo 0 End With 'handling columns where to start writing data from iniColStr = "A" '<-- Here you specify which column to start writing data from iniRow = 1 '<-- Here you specify which row to start writing data from iniCol = MySheet.Range(iniColStr & "1").Column Set BlckNameRng = MySheet.Cells(iniRow, iniCol).Resize(, 1000) ' this will clear excel cells in 1000 columns right of the initial one Set TagsRng = BlckNameRng.Offset(1) With BlckNameRng .EntireColumn.Clear With .Font .Bold = True .Color = 1152 End With End With '------------------------------------------------------- '------------------------------------------------------- 'blocks reference searching&handling Dim myBlckRef As AcadBlockReference Dim Attrs As Variant Dim nBlckRefs As Integer, iBlckRef As Integer, nAttrs As Integer, iAttr As Integer, nTags As Integer Dim BlckName As String, BlckHandle As String Dim gpCode(0) As Integer Dim dataValue(0) As Variant Dim ssetObj As AcadSelectionSet Dim myRow As Long, myCol As Long Dim LBnd As Integer, Ubnd As Integer 'selecting block references in the active drawing gpCode(0) = 0 dataValue(0) = "INSERT" On Error Resume Next Set ssetObj = ThisDrawing.SelectionSets("BlockRefSset") If Err Then Set ssetObj = ThisDrawing.SelectionSets.Add("BlockRefSset") ssetObj.Clear On Error GoTo 0 'ssetObj.Select acSelectionSetAll, , , gpCode, dataValue 'Selects All Objects within dwg automatically ssetObj.SelectOnScreen 'FilterType, FilterData 'User Selects Objects within dwg 'handling block references found nTags = 0 ' this counter will keep track of the number of columns filled with blockreferences data ("handles" and "attributes") nBlckRefs = ssetObj.Count For iBlckRef = 0 To nBlckRefs - 1 Set myBlckRef = ssetObj.Item(iBlckRef) If myBlckRef.HasAttributes Then ' getting blockreference info With myBlckRef BlckName = .Name BlckHandle = .Handle Attrs = .GetAttributes End With LBnd = LBound(Attrs) Ubnd = UBound(Attrs) nAttrs = Ubnd - LBnd + 1 ' handling excel list structure consequent to blockreference blockname Set myCell = BlckNameRng.Find(BlckName, LookIn:=xlValues) ' searching for blockname existence If myCell Is Nothing Then 'if the blockname hasn't already been met-> registered 'then we have to arrange new columns to house blockreference data (handle and attributes tagstrings and textstrings) myCol = nTags + 1 ' setting ref column (where to start writing from) one to the right of the last one nTags = nTags + 1 + nAttrs ' update number of columns to be filled with data: the "1" is for the "handle" column ' writing block header cells With BlckNameRng(1, myCol) .Value = BlckName With .Resize(, nAttrs + 1) .Merge .BorderAround (xlContinuous) .HorizontalAlignment = xlCenter End With End With ' writing blockreference data header cells (handle and attributes tags) With TagsRng(1, myCol) .Value = "HANDLE" .BorderAround (xlContinuous) 'every block data heade is boxed For iAttr = LBnd To Ubnd With .Offset(0, 1 + iAttr - LBnd) .Value = Attrs(iAttr).TagString .BorderAround (xlContinuous) .HorizontalAlignment = xlCenter End With Next iAttr End With Else ' if the blockname has already been listed myCol = myCell.Column - BlckNameRng.Column + 1 'set ref column to the found cell one End If 'writing blockreference data cells With BlckNameRng.Offset(, myCol - 1).EntireColumn myRow = .Cells(.Rows.Count, 1).End(xlUp).Offset(1).Row ' getting the first free cell in the column With .Cells(myRow, 1) .Borders(xlEdgeLeft).LineStyle = xlContinuous ' left border the 1st column .Value = BlckHandle ' writing handle data For iAttr = LBnd To Ubnd .Offset(0, 1 + iAttr - LBnd).Value = Attrs(iAttr).TextString ' writing attributes string data Next iAttr .Offset(0, 1 + Ubnd - LBnd).Borders(xlEdgeRight).LineStyle = xlContinuous ' right border the last column End With End With End If Next iBlckRef '------------------------------------------------------- With BlckNameRng.CurrentRegion .Columns.AutoFit .Select End With Set Excel = Nothing End Sub I have added an option to either select the blocks or automatically select all the blocks in the dwg. This only imports selected blocks with attributes only. It is extremely slow if you have ALOT (a couple hundred) of blocks compared to the blocks2excel.lsp (Which is really fast). It would be interesting to see if the lisp could actually paste it into an open workbook rather than exporting it to a new csv file every time. Definitely getting there. Thank you for the help as always you are the man! (defun c:Blocks2Excel (/ bks int sel ent nm ds b ly f lst fl op) ;;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-explode-all-dynamic-blocks-except-named-blocks/td-p/7700420 ;;--------------------------------------------;; ;; ;; ;; Author : Tharwat 10.June.2015 ;; ;; Modified on 3rd.Aug.2017 to allow users to ;; ;; select specific blocks. ;; ;;--------------------------------------------;; ;; Compute the quantity of all blocks in ;; ;; a drawing and write the outcome to an ;; ;; Excel file format in format .csv ;; ;;--------------------------------------------;; ;; Layer Name:,Block Name:,QTY,Description ;; ;; ;; ;;--------------------------------------------;; (princ"\nSelect blocks :") (if (setq bks (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object))) int -1 sel (ssget '((0 . "INSERT")))) (while (setq ent (ssname sel (setq int (1+ int)))) (if (and (setq nm (vla-get-effectivename (vlax-ename->vla-object ent))) (setq ds (if (vlax-property-available-p (setq b (vla-item bks nm)) 'comments) (vla-get-comments b) "") ) (setq ly (cdr (assoc 8 (entget ent)))) ) (if (vl-some '(lambda (x) (and (eq ly (car x)) (eq nm (cadr x)) (setq f x))) lst) (setq lst (subst (list ly nm (1+ (caddr f)) ds) f lst)) (setq lst (cons (list ly nm 1 ds) lst)) ) ) ) ) (setq lst (vl-sort lst '(lambda (j k) (< (car j) (car k))))) (cond ((not lst) (alert "Couldn't find any block in this drawing !!")) ((and (setq fl (getfiled "Specify new Excel file name" (getvar 'DWGPREFIX) "csv" 1)) (setq op (open fl "w")) ) ;; (write-line "Layer Name:;Block Name:;QTY;Description" op) (write-line "Block Name:-QTY" op) (mapcar '(lambda (x) ;; (write-line (strcat (car x) ";" (cadr x) ";" (itoa (caddr x)) ";" (nth 3 x)) op)) (write-line (strcat (cadr x) "-" (itoa (caddr x))) op)) lst) (close op) ) ) (princ) )(vl-load-com) (c:Blocks2Excel) Edited October 20, 2022 by rcb007 Quote
BIGAL Posted October 20, 2022 Posted October 20, 2022 (edited) Quick answer is yes. Rather than write to a csv file you Putcell writing direct to a cell in Excel. This can be a row or column of data. You have some options easiest is open a new excel and fill in. Can do open file, add to current open excel, change to correct workbook and sheet, add new sheet, plus more. Again post a sample dwg and the excel result. Solved: Text from selection to excel - Page 2 - Autodesk Community - AutoCAD Edited October 20, 2022 by BIGAL Quote
rcb007 Posted October 20, 2022 Author Posted October 20, 2022 Please see the attached dwg and csv. Maybe this will help. This is basic, but its 2 blocks with an attribute. Block Test.dwg blocks test.csv Quote
BIGAL Posted October 20, 2022 Posted October 20, 2022 Will see what I can do bit busy at moment. Quote
