CAD_Noob Posted October 18, 2022 Share Posted October 18, 2022 I need help to modify this lisp. Credit to the author, my friend just gave this to me. What it does is Select multiple Polylines and creates a table of all the selected polylines showing its Layer name and total Length, My issue is that our drawings are in millimeter. Can somebody help me to modify the lisp and change the total length in the table to Meters If we can add a polyline with the layer color in another column of the table, that would be a great addition but not necessary. Here is the lisp : (defun C:LAYLENGTH ( / *error* acdoc ss p i e a d l) (vl-load-com) (setq acdoc (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark acdoc) (defun *error* (msg) (and msg (not (wcmatch (strcase msg) "*CANCEL*,*QUIT*,*BREAK*,*EXIT*")) (princ (strcat "\nError: " msg)) ) (if (= 8 (logand (getvar 'undoctl) 8)) (vla-endundomark acdoc) ) (princ) ) (if (and (setq ss (ssget ":L" '((0 . "LINE,POLYLINE,LWPOLYLINE,ARC,CIRCLE,ELLIPSE,SPLINE")))) (setq p (getpoint "\nTable scale depend on annotation scale.\nSpecify table insert point: ")) ) (progn (repeat (setq i (sslength ss)) (setq e (ssname ss (setq i (1- i))) a (cdr (assoc 8 (entget e))) d (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) ) (if (setq o (assoc a l)) (setq l (subst (list a (+ (cadr o) d)) o l)) (setq l (cons (list a d) l)) ) ) (setq l (vl-sort l '(lambda (a b) (< (car a) (car b))))) (insert_table l p) ) ) (*error* nil) (princ) ) (defun insert_table (lst pct / tab row col ht i n space) (setq space (vlax-get acDoc (if (= 1 (getvar 'cvport)) 'PaperSpace 'ModelSpace)) ht (/ 2.5 (cond ((getvar 'cannoscalevalue)) (1.0))) pct (trans pct 1 0) n (trans '(1 0 0) 1 0 T) tab (setq tab (vla-addtable space (vlax-3d-point pct) (+ 2 (length lst)) (length (car lst)) (* 2.5 ht) ht)) ) (vlax-put tab 'direction n) (mapcar (function (lambda (rowType) (vla-SetTextStyle tab rowType (getvar 'textstyle)) (vla-SetTextHeight tab rowType ht) ) ) '(2 4 1) ) (vla-put-HorzCellMargin tab (* 0.14 ht)) (vla-put-VertCellMargin tab (* 0.14 ht)) (setq lst (cons (mapcar '(lambda (a) (strcat "Col" (itoa (1+ (vl-position a (car lst)))))) (car lst)) lst)) (setq i 0) (foreach col (apply 'mapcar (cons 'list lst)) (vla-SetColumnWidth tab i (apply 'max (mapcar '(lambda (x) ((lambda (txb) (+ (abs (- (caadr txb) (caar txb))) (* 2.0 ht))) (textbox (list (cons 1 (vl-princ-to-string x)) (cons 7 (getvar 'textstyle)) (cons 40 ht))) ) ) col ) ) ) (setq i (1+ i)) ) (setq lst (cons '("TITLE") lst)) (setq row 0) (foreach r lst (setq col 0) (vla-SetRowHeight tab row (* 1.5 ht)) (foreach c r (vla-SetText tab row col (if (numberp c) (rtos c) (vl-princ-to-string c))) (setq col (1+ col)) ) (setq row (1+ row)) ) ) Quote Link to comment Share on other sites More sharing options...
mhupp Posted October 18, 2022 Share Posted October 18, 2022 Divide c by 1000 when its a number. replace the last part of the lisp. (foreach r lst (setq col 0) (vla-SetRowHeight tab row (* 1.5 ht)) (foreach c r (vla-SetText tab row col (if (numberp c) (rtos (/ c 1000) 2 3) ;change 3 to show that many decimal places (vl-princ-to-string c) ) ) (setq col (1+ col)) ) (setq row (1+ row)) ) ) 2 Quote Link to comment Share on other sites More sharing options...
CAD_Noob Posted October 19, 2022 Author Share Posted October 19, 2022 (edited) 12 hours ago, mhupp said: Divide c by 1000 when its a number. replace the last part of the lisp. (foreach r lst (setq col 0) (vla-SetRowHeight tab row (* 1.5 ht)) (foreach c r (vla-SetText tab row col (if (numberp c) (rtos (/ c 1000) 2 3) ;change 3 to show that many decimal places (vl-princ-to-string c) ) ) (setq col (1+ col)) ) (setq row (1+ row)) ) ) Thank you so much... I want to do the same to this lisp...Making tables by giving height to polylines - AutoLISP, Visual LISP & DCL - AutoCAD Forums (cadtutor.net) Edited October 19, 2022 by CAD_Noob Quote Link to comment Share on other sites More sharing options...
CAD_Noob Posted October 19, 2022 Author Share Posted October 19, 2022 13 hours ago, mhupp said: Divide c by 1000 when its a number. replace the last part of the lisp. (foreach r lst (setq col 0) (vla-SetRowHeight tab row (* 1.5 ht)) (foreach c r (vla-SetText tab row col (if (numberp c) (rtos (/ c 1000) 2 3) ;change 3 to show that many decimal places (vl-princ-to-string c) ) ) (setq col (1+ col)) ) (setq row (1+ row)) ) ) Can i ask for one more? How do i change the Title in the table to match with the drawing filename without the .dwg extension? Quote Link to comment Share on other sites More sharing options...
mhupp Posted October 19, 2022 Share Posted October 19, 2022 (edited) 2 hours ago, CAD_Noob said: Can i ask for one more? How do i change the Title in the table to match with the drawing filename without the .dwg extension? (setq lst (cons '("TITLE") lst)) ;replace this line (setq lst (cons (vl-filename-base (getvar 'dwgname)) lst)) ;with this --edit also near the end Edited October 19, 2022 by mhupp 1 Quote Link to comment Share on other sites More sharing options...
CAD_Noob Posted October 19, 2022 Author Share Posted October 19, 2022 1 hour ago, mhupp said: (setq lst (cons '("TITLE") lst)) ;replace this line (setq lst (cons (vl-filename-base (getvar 'dwgname)) lst)) ;with this --edit also near the end Thank you so much... I only put getvar 'dwgname it doesn't work hehehe. Quote Link to comment Share on other sites More sharing options...
