Guest Posted October 20, 2022 Share Posted October 20, 2022 HI mhupp. Did you see the code? Thanks Quote Link to comment Share on other sites More sharing options...
mhupp Posted October 20, 2022 Share Posted October 20, 2022 (edited) Got rid of all the repeating code. just update the laylst at the start with the layers you want to check. (defun c:FOO (/ laylst SSP SST lst obj F TXT) (setq laylst '("PST_KAEK" "TOPO_PROP" "TOPO_PROP_NEW" "BLD" "VST" "EAS" "MINE" "VST_FINAL" "EAS_FINAL" "MINE_FINAL" "DGM_PROP_FINAL" "AREA_D" "AREA_A")) (foreach lay laylst (setq SSP nil SST nil) ;clear last selection sets (if (not (setq SSP (ssget "_X" (list '(0 . "*POLYLINE") (cons 8 lay) '(70 . 0))))) (setq SSP (ssadd)) ) (if (not (setq SST (ssget "_X" (list '(0 . "TEXT") (cons 8 lay))))) (setq SST (ssadd)) ) (setq lst (cons (list lay (rtos (sslength SSP) 2 0) (rtos (sslength SST) 2 0)) lst)) (foreach poly (vl-remove-if 'listp (mapcar 'cadr (ssnamex SSP))) (if (and (setq obj (vlax-ename->vla-object poly)) (equal (vlax-curve-getstartpoint poly) (vlax-curve-getendpoint poly) 1e-4)) (vlax-put obj 'Coordinates (reverse (cdr (cdr (reverse (vlax-get obj 'Coordinates)))))) );end if start-end (vla-put-Closed obj :vlax-true) (vla-Update obj) ) ) (setq lst (reverse lst)) (setq F (open (setq txt (strcat (getvar "TEMPPREFIX") "TEXTFILE.TXT")) "w")) (write-line "=========================================================" F) (write-line " Results " F) (write-line "=========================================================" F) (foreach line lst (write-line (strcat "Layer: " (car line)) F) (if (eq (cadr line) "0") (write-line "No Open Polylines Found" F) (write-line (strcat (cadr line) " Polyline Closed") F) ) (if (eq (caddr line) "0") (write-line "No Text Found" F) (write-line (strcat (caddr line) " Text Found") F) ) ) (close F) (startapp "NOTEPAD" txt) (princ) ) ;end defun ========================================================= Results ========================================================= Layer: PST_KAEK 1 Polyline Closed 5 Text Found Layer: TOPO_PROP No Open Polylines Found No Text Found Edited October 21, 2022 by mhupp Quote Link to comment Share on other sites More sharing options...
Guest Posted October 20, 2022 Share Posted October 20, 2022 Thanks mhupp. I will check code the morning !! Quote Link to comment Share on other sites More sharing options...
Guest Posted October 21, 2022 Share Posted October 21, 2022 (edited) Hi mhupp. Thanks for the code. I try to add a filter to print result only for exist layers . Is no need to print the other extra lines !! I Block the line to close the polyline and i prefare to count and report the open and not write "No Open Polylines Found" (defun c:FOO (/ laylst SSP SST lst obj F TXT) (setq laylst '("PST_KAEK" "TOPO_PROP" "TOPO_PROP_NEW" "BLD" "VST" "EAS" "MINE" "VST_FINAL" "EAS_FINAL" "MINE_FINAL" "DGM_PROP_FINAL" "AREA_D" "AREA_A")) (foreach lay laylst (setq SSP nil SST nil) ;clear last selection sets (if (not (setq SSP (ssget "_X" (list '(0 . "*POLYLINE") (cons 8 lay) '(70 . 0))))) (setq SSP (ssadd)) ) (if (not (setq SST (ssget "_X" (list '(0 . "TEXT") (cons 8 lay))))) (setq SST (ssadd)) ) (setq lst (cons (list lay (rtos (sslength SSP) 2 0) (rtos (sslength SST) 2 0)) lst)) (foreach poly (vl-remove-if 'listp (mapcar 'cadr (ssnamex SSP))) (if (and (setq obj (vlax-ename->vla-object poly)) (equal (vlax-curve-getstartpoint poly) (vlax-curve-getendpoint poly) 1e-4)) (vlax-put obj 'Coordinates (reverse (cdr (cdr (reverse (vlax-get obj 'Coordinates)))))) );end if start-end ; (vla-put-Closed obj :vlax-true) ;This could add gemoetiry somewhere you don't want <--- I do this change (vla-Update obj) ) ) (setq lst (reverse lst)) (setq F (open (setq txt (strcat (getvar "TEMPPREFIX") "TEXTFILE.TXT")) "w")) (write-line "=========================================================" F) (write-line " Results " F) (write-line "=========================================================" F) (foreach line lst (if (tblsearch "layer" (car line)) ; <------ I add this line (write-line (strcat "Layer: " (car line)) F) ) ; <------ I add this line (if (eq (cadr line) "0") (write-line "No Open Polylines Found" F) (write-line (strcat (cadr line) " Polyline Closed") F) ) (if (eq (caddr line) "0") (write-line "No Text Found" F) (write-line (strcat (caddr line) " Text Found") F) ) ) (close F) (startapp "NOTEPAD" txt) (princ) ) ;end defun Quote ========================================================= Results ========================================================= Layer: PST_KAEK No Open Polylines Found 1 Text Found Layer: TOPO_PROP No Open Polylines Found No Text Found No Open Polylines Found No Text Found Layer: BLD No Open Polylines Found 4 Text Found Layer: VST No Open Polylines Found 3 Text Found No Open Polylines Found No Text Found No Open Polylines Found No Text Found Layer: VST_FINAL No Open Polylines Found No Text Found No Open Polylines Found No Text Found No Open Polylines Found No Text Found No Open Polylines Found No Text Found No Open Polylines Found No Text Found No Open Polylines Found No Text Found Edited October 21, 2022 by prodromosm Quote Link to comment Share on other sites More sharing options...
Guest Posted October 21, 2022 Share Posted October 21, 2022 I update the code. I have an error Quote ; error: bad argument type: stringp #<file "C:\\Users\\Prodromos\\appdata\\local\\temp\\TEXTFILE.TXT"> And i want to add a line (write-line (strcat "- Found " (cadr line) " Open Polyline to Layer " (car line)) F) (defun c:FOO (/ laylst SSP SST lst obj F TXT) (setq laylst '("PST_KAEK" "TOPO_PROP" "TOPO_PROP_NEW" "BLD" "VST" "EAS" "MINE" "VST_FINAL" "EAS_FINAL" "MINE_FINAL" "DGM_PROP_FINAL" "AREA_D" "AREA_A")) (foreach lay laylst (setq SSP nil SST nil) ;clear last selection sets (if (not (setq SSP (ssget "_X" (list '(0 . "*POLYLINE") (cons 8 lay) '(70 . 0))))) (setq SSP (ssadd)) ) (if (not (setq SST (ssget "_X" (list '(0 . "TEXT") (cons 8 lay))))) (setq SST (ssadd)) ) (setq lst (cons (list lay (rtos (sslength SSP) 2 0) (rtos (sslength SST) 2 0)) lst)) (foreach poly (vl-remove-if 'listp (mapcar 'cadr (ssnamex SSP))) (if (and (setq obj (vlax-ename->vla-object poly)) (equal (vlax-curve-getstartpoint poly) (vlax-curve-getendpoint poly) 1e-4)) (vlax-put obj 'Coordinates (reverse (cdr (cdr (reverse (vlax-get obj 'Coordinates)))))) );end if start-end ;(vla-put-Closed obj :vlax-true) (vla-Update obj) ) ) (setq lst (reverse lst)) (setq F (open (setq txt (strcat (getvar "TEMPPREFIX") "TEXTFILE.TXT")) "w")) (write-line "=========================================================" F) (write-line " Results " F) (write-line "=========================================================" F) (foreach line lst (if (=(tblsearch "layer" (car line))) (write-line (strcat "- Found " (cadr line) " Close Polyline to Layer " (car line)) F) ) (if (eq (caddr line) "0") (write-line (strcat "- Found 0 Text to Layer " (car line)) F) (write-line (strcat "- Found " (caddr line) " Text to Layer " (car line) F)) ) ) (close F) (startapp "NOTEPAD" txt) (princ) ) ;end defun Quote Link to comment Share on other sites More sharing options...
mhupp Posted October 21, 2022 Share Posted October 21, 2022 (edited) Error Hit https://www.cadtutor.net/forum/topic/76177-help-close-open-polylines-delete-extra-vertexand-report/?do=findComment&comment=602139 Good idea, prob best to layer check when making the list tho. This will take care of both outputs for poly and text if the layer isn't in the drawing. (if (tblsearch "layer" lay) (setq lst (cons (list lay (rtos (sslength SSP) 2 0) (rtos (sslength SST) 2 0)) lst)) ) ... (if (eq (cadr line) "0") (write-line (strcat "- Found 0 Open Polyline on Layer " (car line)) F) (write-line (strcat "- Found & Closed " (cadr line) " Open Polyline on Layer " (car line)) F) ) Edited October 21, 2022 by mhupp Quote Link to comment Share on other sites More sharing options...
Guest Posted October 21, 2022 Share Posted October 21, 2022 Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted October 22, 2022 Share Posted October 22, 2022 Hi mhupp. I try to add a second list of layers only for the text .Visual lisp editor can not find any errors but when i run the lisp have this message. Can you help? Quote ; error: bad argument type: stringp nil (defun c:test (/ laylst SSP SST lst obj F TXT) (setq laylst '("PST_KAEK" "TOPO_PROP" "TOPO_PROP_NEW" "BLD" "VST" "EAS" "MINE" "VST_FINAL" "EAS_FINAL" "MINE_FINAL" "DGM_PROP_FINAL" "AREA_D" "AREA_A")) (setq laylst2 '("DBOUND_AIG" "DBOUND_PRL" "DBOUND_PAIG" "DBOUND_REM" "DBOUND_APAL" "DBOUND_APAL" "ROAD" "OT" "PST_KAEK" "BLD" "VST" "EAS")) (foreach lay laylst lay2 laylst2 (setq SSP nil SST nil) ;clear last selection sets (if (not (setq SSP (ssget "_X" (list '(0 . "*POLYLINE") (cons 8 lay) '(70 . 0))))) (setq SSP (ssadd)) ) (if (not (setq SST (ssget "_X" (list '(0 . "TEXT") (cons 8 lay))))) (setq SST (ssadd)) ) (if (tblsearch "layer" lay) (setq lst (cons (list lay (rtos (sslength SSP) 2 0)) lst)) ) (if (tblsearch "layer" lay2) (setq 2nd (cons (list lay2 (rtos (sslength SST) 2 0)) 2nd)) ) (foreach poly (vl-remove-if 'listp (mapcar 'cadr (ssnamex SSP))) (if (and (setq obj (vlax-ename->vla-object poly)) (equal (vlax-curve-getstartpoint poly) (vlax-curve-getendpoint poly) 1e-4)) (vlax-put obj 'Coordinates (reverse (cdr (cdr (reverse (vlax-get obj 'Coordinates)))))) );end if start-end (vla-put-Closed obj :vlax-true) (vla-Update obj) ) ) (setq lst (reverse lst)) (setq 2nd (reverse 2nd)) (setq F (open (setq txt (strcat (getvar "TEMPPREFIX") "TEXTFILE.TXT")) "w")) (write-line "=========================================================" F) (write-line " Results " F) (write-line "=========================================================" F) (foreach line lst (if (eq (cadr line) "0") (write-line (strcat "- " (cadr line) " Polyline found on Layer " (car line)) F) ) (if (eq (caddr line) "0") (write-line (strcat "- " (caddr line) " Text found on Layer " (car line) F)) ) ) (close F) (startapp "NOTEPAD" txt) (princ) ) ;end defun Thanks Quote Link to comment Share on other sites More sharing options...
mhupp Posted October 22, 2022 Share Posted October 22, 2022 (edited) Just add them to laylst. (setq laylst '("PST_KAEK" "TOPO_PROP" "TOPO_PROP_NEW" "BLD" "VST" "EAS" "MINE" "VST_FINAL" "EAS_FINAL" "MINE_FINAL" "DGM_PROP_FINAL" "AREA_D" "AREA_A" "DBOUND_AIG" "DBOUND_PRL" "DBOUND_PAIG" "DBOUND_REM" "DBOUND_APAL" "DBOUND_APAL" "ROAD" "OT" "PST_KAEK" "BLD" "VST" "EAS") ) Edited October 22, 2022 by mhupp Quote Link to comment Share on other sites More sharing options...
Guest Posted October 22, 2022 Share Posted October 22, 2022 (edited) Hi mhupp.I make a second laylist because I don't want to search for polylines in these layers and not write "0 polylines in layer ........... ". I want to search only for text in this laylist.Is it possible to have a second laylist? The idea is to have something like this (write-line "============================================================" F) (write-line " Close Polyline & Layers " F) (write-line "============================================================" F) (write-line "=========================================================" F) (write-line " Text & Layers " F) (write-line "=========================================================" F) Thanks Edited October 22, 2022 by prodromosm Quote Link to comment Share on other sites More sharing options...
mhupp Posted October 22, 2022 Share Posted October 22, 2022 If that is what you want to do your going to have to make a separate foreach for the 2nd list. that generates a separate list to output to the text file. laylst1 laylst2 foreach laylst1 ... foreach laylst2 ... (write-line "============================================================" F) (write-line " Close Polyline & Layers " F) (write-line "============================================================" F) foreach line lstPoly ... (write-line "=========================================================" F) (write-line " Text & Layers " F) (write-line "=========================================================" F) foreach line lstText ... Quote Link to comment Share on other sites More sharing options...
Guest Posted October 22, 2022 Share Posted October 22, 2022 Hi mhupp.I did the change. The code works but the results in not correct.I have close polylines in the drowing and the result say 0 close polyline !!. For the text say nothing (defun c:test (/ laylst SSP SST lstPoly lstText obj F TXT) (setq laylst1 '("PST_KAEK" "TOPO_PROP" "TOPO_PROP_NEW" "BLD" "VST" "EAS" "MINE" "VST_FINAL" "EAS_FINAL" "MINE_FINAL" "DGM_PROP_FINAL" "AREA_D" "AREA_A")) (setq laylst2 '("DBOUND_AIG" "DBOUND_PRL" "DBOUND_PAIG" "DBOUND_REM" "DBOUND_APAL" "DBOUND_APAL" "ROAD" "OT" "PST_KAEK" "BLD" "VST" "EAS")) ;-------------laylist1---------------------------------------------- (foreach lay laylst1 (setq SSP nil) ;clear last selection sets (if (not (setq SSP (ssget "_X" (list '(0 . "*POLYLINE") (cons 8 lay) '(70 . 0))))) (setq SSP (ssadd)) ) (if (tblsearch "layer" lay) (setq lstPoly (cons (list lay (rtos (sslength SSP) 2 0)) lstPoly)) ) (foreach poly (vl-remove-if 'listp (mapcar 'cadr (ssnamex SSP))) (if (and (setq obj (vlax-ename->vla-object poly)) (equal (vlax-curve-getstartpoint poly) (vlax-curve-getendpoint poly) 1e-4)) (vlax-put obj 'Coordinates (reverse (cdr (cdr (reverse (vlax-get obj 'Coordinates)))))) );end if start-end (vla-put-Closed obj :vlax-true) (vla-Update obj) ) ) ;-------------laylist2---------------------------------------------- (foreach lay2 laylst2 (setq SST nil) ;clear last selection sets (if (not (setq SST (ssget "_X" (list '(0 . "TEXT") (cons 8 lay2))))) (setq SST (ssadd)) ) (if (tblsearch "layer" lay2) (setq lstText (cons (list lay2 (rtos (sslength SST) 2 0)) lstText)) ) ) ;-------------------------------------------------------------------------------- (setq lstPoly (reverse lstPoly)) (setq lstText (reverse lstText)) (setq F (open (setq txt (strcat (getvar "TEMPPREFIX") "TEXTFILE.TXT")) "w")) ;-------------write laylist1---------------------------------------------- (write-line "============================================================" F) (write-line " Close Polyline & Layers " F) (write-line "============================================================" F) (write-line "" F) (foreach line lstPoly (if (eq (cadr line) "0") (write-line (strcat "- " (cadr line) " Close Polyline found on Layer " (car line)) F) ) ) ;-------------write laylist2---------------------------------------------- (write-line "=========================================================" F) (write-line " Text & Layers " F) (write-line "=========================================================" F) (write-line "" F) (foreach line lstText (if (eq (caddr line) "0") (write-line (strcat "- " (caddr line) " Text found on Layer " (car line) F)) ) ) (close F) (startapp "NOTEPAD" txt) (princ) ) ;end defun test file.dwg Quote Link to comment Share on other sites More sharing options...
mhupp Posted October 22, 2022 Share Posted October 22, 2022 change your if statements. (if (not (eq (caddr line) "0")) ;either add a not will only display layers that have a count or (if (eq (caddr line) "0")) ;will display all layers 0's and #'s (write-line (strcat "- 0 Close Polyline found on Layer " (car line)) F) (write-line (strcat "- " (cadr line) " Close Polyline found on Layer " (car line)) F) ) Quote Link to comment Share on other sites More sharing options...
Guest Posted October 22, 2022 Share Posted October 22, 2022 (edited) in the previous code we have this (if (eq (cadr line) "0") (write-line (strcat "- " (cadr line) " Polyline found on Layer " (car line)) F) ) (if (eq (caddr line) "0") (write-line (strcat "- " (caddr line) " Text found on Layer " (car line) F)) ) ) I did your change anyway but i have this error Quote ; error: bad argument type: stringp nil I confused !!!!!! (defun c:test (/ laylst SSP SST lstPoly lstText obj F TXT) (setq laylst1 '("PST_KAEK" "TOPO_PROP" "TOPO_PROP_NEW" "BLD" "VST" "EAS" "MINE" "VST_FINAL" "EAS_FINAL" "MINE_FINAL" "DGM_PROP_FINAL" "AREA_D" "AREA_A")) (setq laylst2 '("DBOUND_AIG" "DBOUND_PRL" "DBOUND_PAIG" "DBOUND_REM" "DBOUND_APAL" "DBOUND_APAL" "ROAD" "OT" "PST_KAEK" "BLD" "VST" "EAS")) ;-------------laylist1---------------------------------------------- (foreach lay laylst1 (setq SSP nil) ;clear last selection sets (if (not (setq SSP (ssget "_X" (list '(0 . "*POLYLINE") (cons 8 lay) '(70 . 0))))) (setq SSP (ssadd)) ) (if (tblsearch "layer" lay) (setq lstPoly (cons (list lay (rtos (sslength SSP) 2 0)) lstPoly)) ) (foreach poly (vl-remove-if 'listp (mapcar 'cadr (ssnamex SSP))) (if (and (setq obj (vlax-ename->vla-object poly)) (equal (vlax-curve-getstartpoint poly) (vlax-curve-getendpoint poly) 1e-4)) (vlax-put obj 'Coordinates (reverse (cdr (cdr (reverse (vlax-get obj 'Coordinates)))))) );end if start-end (vla-put-Closed obj :vlax-true) (vla-Update obj) ) ) ;-------------laylist2---------------------------------------------- (foreach lay2 laylst2 (setq SST nil) ;clear last selection sets (if (not (setq SST (ssget "_X" (list '(0 . "TEXT") (cons 8 lay2))))) (setq SST (ssadd)) ) (if (tblsearch "layer" lay2) (setq lstText (cons (list lay2 (rtos (sslength SST) 2 0)) lstText)) ) ) ;-------------------------------------------------------------------------------- (setq lstPoly (reverse lstPoly)) (setq lstText (reverse lstText)) (setq F (open (setq txt (strcat (getvar "TEMPPREFIX") "TEXTFILE.TXT")) "w")) ;-------------write laylist1---------------------------------------------- (write-line "============================================================" F) (write-line " Close Polyline & Layers " F) (write-line "============================================================" F) (write-line "" F) (foreach line lstPoly (if (not (eq (caddr line) "0")) (write-line (strcat "- " (cadr line) " Close Polyline found on Layer " (car line)) F) ) ) ;-------------write laylist2---------------------------------------------- (write-line "=========================================================" F) (write-line " Text & Layers " F) (write-line "=========================================================" F) (write-line "" F) (foreach line lstText (if (not (eq (caddr line) "0")) (write-line (strcat "- " (caddr line) " Text found on Layer " (car line) F)) ) ) (close F) (startapp "NOTEPAD" txt) (princ) ) ;end defun Edited October 22, 2022 by prodromosm Quote Link to comment Share on other sites More sharing options...
mhupp Posted October 22, 2022 Share Posted October 22, 2022 In my code i had two outputs if true if false Yours only has one so it only outputs if true (if (eq (cadr line) "0") (write-line (strcat "- Found & Closed 0 Open Polyline on Layer " (car line)) F) ;if true output this line (write-line (strcat "- Found & Closed " (cadr line) " Open Polyline on Layer " (car line)) F) ;if false output this line ) You changed it to (if (eq (cadr line) "0") (write-line (strcat "- " (cadr line) " Polyline found on Layer " (car line)) F) ;missing false write-line ) Because their isn't a false statment this will only output when true and since its only true "0" it will only output "- Found & Closed 0 Open Polyline on Layer "layername" This will output anything that isn't equal to 0 (if (not (eq (cadr line) "0")) (write-line (strcat "- " (cadr line) " Polyline found on Layer " (car line)) F) ) but that's not whats is causing the error its the write-line again. the list only has two elements now. Error 1 - (caddr line) is nil since their isn't a third element Error 2 - and having ) in the wrong place (write-line (strcat "- " (caddr line) " Text found on Layer " (car line) F)) ;wrong (write-line (strcat "- " (cadr line) " Text found on Layer " (car line)) F) ;right fixed code (defun c:test (/ laylst SSP SST lstPoly lstText obj F TXT) (setq laylst1 '( "PST_KAEK" "TOPO_PROP" "TOPO_PROP_NEW" "BLD" "VST" "EAS" "MINE" "VST_FINAL" "EAS_FINAL" "MINE_FINAL" "DGM_PROP_FINAL" "AREA_D" "AREA_A")) (setq laylst2 '( "DBOUND_AIG" "DBOUND_PRL" "DBOUND_PAIG" "DBOUND_REM" "DBOUND_APAL" "DBOUND_APAL" "ROAD" "OT" "PST_KAEK" "BLD" "VST" "EAS")) ;-------------laylist1---------------------------------------------- (foreach lay laylst1 (setq SSP nil) ;clear last selection sets (if (not (setq SSP (ssget "_X" (list '(0 . "*POLYLINE") (cons 8 lay) '(70 . 0))))) (setq SSP (ssadd)) ) (if (tblsearch "layer" lay) (setq lstPoly (cons (list lay (rtos (sslength SSP) 2 0)) lstPoly)) ) (foreach poly (vl-remove-if 'listp (mapcar 'cadr (ssnamex SSP))) (if (and (setq obj (vlax-ename->vla-object poly)) (equal (vlax-curve-getstartpoint poly) (vlax-curve-getendpoint poly) 1e-4)) (vlax-put obj 'Coordinates (reverse (cdr (cdr (reverse (vlax-get obj 'Coordinates)))))) ) ;end if start-end (vla-put-Closed obj :vlax-true) (vla-Update obj) ) ) ;-------------laylist2---------------------------------------------- (foreach lay2 laylst2 (setq SST nil) ;clear last selection sets (if (not (setq SST (ssget "_X" (list '(0 . "TEXT") (cons 8 lay2))))) (setq SST (ssadd)) ) (if (tblsearch "layer" lay2) (setq lstText (cons (list lay2 (rtos (sslength SST) 2 0)) lstText)) ) ) (setq lstPoly (reverse lstPoly)) (setq lstText (reverse lstText)) ;-------------write laylist1---------------------------------------------- (setq F (open (setq txt (strcat (getvar "TEMPPREFIX") "TEXTFILE.TXT")) "w")) (write-line "============================================================" F) (write-line " Close Polyline & Layers " F) (write-line "============================================================" F) (write-line "" F) (foreach line lstPoly (if (not (eq (cadr line) "0")) (write-line (strcat "- " (cadr line) " Close Polyline found on Layer " (car line)) F) ) ) ;-------------write laylist2---------------------------------------------- (write-line "" F) (write-line "============================================================" F) (write-line " Text & Layers " F) (write-line "============================================================" F) (write-line "" F) (foreach line lstText (if (not (eq (cadr line) "0")) (write-line (strcat "- " (cadr line) " Text found on Layer " (car line)) F) ) ) (close F) (startapp "NOTEPAD" txt) (princ) ) ;end defun will output ============================================================ Close Polyline & Layers ============================================================ - 3 Close Polyline found on Layer BLD ========================================================= Text & Layers ========================================================= - 1 Text found on Layer ROAD - 1 Text found on Layer PST_KAEK - 2 Text found on Layer BLD - 3 Text found on Layer VST Quote Link to comment Share on other sites More sharing options...
Guest Posted October 22, 2022 Share Posted October 22, 2022 Thanks for your time mhupp, but the code still not working properly because i have close polylines in layers VST_FINAL PST_KAEK VST and i have no results for them !!!!! Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted October 22, 2022 Share Posted October 22, 2022 I understand sory.Your code finds only the open polylines and report that close a number of them, not report all close polyline in the layer. OK Thanks Quote Link to comment Share on other sites More sharing options...
