mstb Posted October 16, 2022 Share Posted October 16, 2022 Hello everybody I load linetype In this way (command "_.LINETYPE" "_L" Ltp Dirs "") Is there anyway? Quote Link to comment Share on other sites More sharing options...
mhupp Posted October 16, 2022 Share Posted October 16, 2022 here are three (vla-load (vla-get-linetypes (vla-get-activedocument (vlax-get-acad-object))) "LineTypeName" "FileName.lin" ) http://www.lee-mac.com/loadlinetype.html 2 Quote Link to comment Share on other sites More sharing options...
mstb Posted October 16, 2022 Author Share Posted October 16, 2022 18 minutes ago, mhupp said: here are three (vla-load (vla-get-linetypes (vla-get-activedocument (vlax-get-acad-object))) "LineTypeName" "FileName.lin" ) http://www.lee-mac.com/loadlinetype.html Thank you very much Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted October 16, 2022 Share Posted October 16, 2022 I know it can be confusing during drafting, but anyway worth mention is that actually you can easily load them all simultaneously by just typing LT (LINETYPE) command and then input "*" when asked for type, though you still have to point to adequate *.lin file that have definitions... Quote Link to comment Share on other sites More sharing options...
tombu Posted October 16, 2022 Share Posted October 16, 2022 I've used Lee's code for loading groups of linetypes in macros for years. Make sure to load any Text Styles or shape files with shapes referenced in those definitions first in your macros as well so they will display correctly. Quote Link to comment Share on other sites More sharing options...
tombu Posted October 17, 2022 Share Posted October 17, 2022 Adding a few example macros from my Linetypes drop-down added to the Properties ribbon tab of my custom cuix file. As most of us use visual lisp it's easier to add (vl-load-com) to acaddoc.lsp than adding it to every lisp or macro. Keeping all my lin files in the same support folder as acad.lin makes accessing them easier. Loading lin files using Lee Mac's code: Reload Current ^C^C^P(or LM:LoadLinetypes (load "LoadLinetypesV1-3.lsp"))(LM:LoadLinetypes (list(getvar "celtype")) T) Reload All ^C^C^P(or LM:LoadLinetypes (load "LoadLinetypesV1-3.lsp"))(LtRedef) Dots ^C^C^P(or NewStyle (load "NewStyle.lsp"))(NewStyle "Arial" "arial.ttf") (or LM:LoadLinetypes (load "LoadLinetypesV1-3.lsp"))(LM:LoadLinetypes '("ArialDOT" "ArialDOT2" "ArialDOTX2" "PlusPlus") T) LT Curves ^C^C^P(or LM:LoadLinetypes (load "LoadLinetypesV1-3.lsp"))(LM:LoadLinetypes '("C25" "C-25" "C50" "C-50" "TREELINE_L" "TREELINE_R") T) LT Fences Walls ^C^C^P(or LM:LoadLinetypes (load "LoadLinetypesV1-3.lsp"))(LM:LoadLinetypes '("FENCELINE1" "FENCELINE2" "FENCE" "FENCE2" "FENCE5" "RD-Fence" "FENCE-BOX" "FENCE-BOX2" "FENCE-BOX4" "FENCE-BOX8" "FENCE-DIA" "FENCE-DIA2" "FENCE-DIA4" "FENCE-HW" "FENCE-H1" "FENCE-H2" "FENCE-O" "FENCE-X" "FENCE-Alan" "FENCE-X2" "FENCE-X4" "FENCE-O2" "BARBWIRE_1" "BARBWIRE_2" "CHAINLINK_1" "CHAINLINK_2" "STOCKADE_1" "STOCKADE_2" "STONEWALL") T) LT Dir Arrows ^C^C^P(or NewStyle (load "NewStyle.lsp"))(NewStyle "Arial" "arial.ttf") (or LM:LoadLinetypes (load "LoadLinetypesV1-3.lsp"))(LM:LoadLinetypes '("DIRECTION" "DIRECTION2" "DIRECTION5" "DIRECTION-A" "ArialARROW" "ArialAHead" "ArialTriangle") T) LT Danger ^C^C^P(or NewStyle (load "NewStyle.lsp"))(NewStyle "WINGDINGS" "wingding.ttf") (or LM:LoadLinetypes (load "LoadLinetypesV1-3.lsp"))(LM:LoadLinetypes '("Danger") T) Creating linetypes with text with ronjonp's lisp at https://www.theswamp.org/index.php?topic=47058.msg520876#msg520876 Everyone should have this, Thanks ronjonp! ^C^C^P(or C:makelt (load "makelt.lsp"));makelt Editing lin files: Edit Acad.lin ^C^C_start;acad.lin; Edit Arial.lin ^C^C_start;Arial.lin; Edit BOUCLES.lin ^C^C_start;BOUCLES.lin; List all Shape Names from all loaded Shape files using ShapeNames.lsp by lido. Handy if you only have the shx file not the shp. ^C^C^P(if(not ShapeNames)(load "ShapeNames.lsp"))(ShapeNames);; Code I added to bottom of Lee's LoadLinetypesV1-3.lsp for reloading all linetypes: ;Reload All Loaded Linetypes (defun LtRedef ( / acadObj doc ltlay) (setq acadObj (vlax-get-acad-object) doc (vla-get-ActiveDocument acadObj) ) (vlax-for obj (vla-get-linetypes doc) (if (not (wcmatch (vla-get-name obj) "*|*,Continuous,ByBlock,ByLayer")) (setq ltlay (cons (vla-get-name obj) ltlay)) ) ) (LM:loadlinetypes ltlay T) (vla-Regen doc acActiveViewport) ) Required lin, shx, shp and lsp files attached, adding Arial, wingdings and wingdings3 text styles are done with attached NewStyle.lsp wingdings.lin wingdings3.lin Arial.lin boucles.lin acad.lin boucles.shp boucles.shx NewStyle.lsp 1 Quote Link to comment Share on other sites More sharing options...
