Siz Posted October 15, 2022 Share Posted October 15, 2022 Hi all, I've been mucking around with 3D for a few months and have come up against this issue. I want to be able to 'union' this model with a solid I've already created. But I just can't make a solid of these surfaces. Is this a watertight issue? How can I tell? Or a problem with combining different types of entities into a solid. Or somethng else??? I've rebuilt this model several times carefully to eliminate watertight issues, but with no joy. I've included a DWG of what I've been able to put together so far, plus the basic linework that I'm trying to make solid from. There is a 'loft' involved. Any help appreciated. TIA SAMPLE.dwg Quote Link to comment Share on other sites More sharing options...
Cad64 Posted October 15, 2022 Share Posted October 15, 2022 Hmmmm, I just ran the LOFT command, selected the the spline and the polyline, and it created a 3D Solid. Is this what you're trying to do? I have attached the dwg. 3D Solid.dwg 2 Quote Link to comment Share on other sites More sharing options...
Siz Posted October 16, 2022 Author Share Posted October 16, 2022 Many thanks for that. Yes, that's exactly what I need. When I try the 'loft' from the two closed polylines I end up with some nurbsurfaces that I can't seem to do anything with. Any settings you can think of that I might need to change? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted October 16, 2022 Share Posted October 16, 2022 52 minutes ago, Siz said: Any settings you can think of that I might need to change? Yes, when you initiate the LOFT command, watch your command line. You will have some options. One of the options is MOde, so type MO and hit Enter and then choose Solid. Then click your two polylines and it should create a 3D Solid. 3 Quote Link to comment Share on other sites More sharing options...
Siz Posted October 17, 2022 Author Share Posted October 17, 2022 Aw, thank you so much. That's massively helpful. Superb! Quote Link to comment Share on other sites More sharing options...
