Search for a word within long Mtext ( above 250 characters) and select all text which contain that particular word
Hi All,
Newbie into Lisp here. I am trying to find a way to search for a particular word within a long MTEXT and select all that text
I compiled a short code from what I found here on this forum but I can't make it work:
(defun C:seltxt (/ SS)
  (setq SS (ssget "_X" (list '(0 . "*TEXT") '(1 . "*DESIGNER*") '(3 . "*DESIGNER*") (cons 410 (getvar 'ctab)))))
  (sssetfirst nil ss)
Any help with fixing this would be beneficial
Please find attached an example DWG
TEST1.dwg
Edited by SLW210
Added Code Tags!
For your search you will need to put an OR statement to get the 1 or 3 texts, at the moment it is searching 1 and 3 and if true for both (Lee Mac has a good explanation and examples on his website)
I tried this and -quickly- just searching for '(3 . "*DESIGNER*") didn't work for me, but '(1 did... not sure why yet though.
  • Agree 1
like StevenP said
This needs an or logic. what your ssget is looking for text that have both 1and 3 strings. were you need to be looking for one or the other.
http://www.lee-mac.com/ssget.html#logical
  (setq SS (ssget "_X" (list '(0 . "*TEXT") '(-4 . "<OR") '(1 . "*DESIGNER*") '(3 . "*DESIGNER*")  '(-4 . "OR>") (cons 410 (getvar 'ctab)))))
  (sssetfirst nil ss)
--edit
'(3 . "*DESIGNER*") worked for me Steven. Looks like SLW210 updated the file maybe thats why?
Edited by mhupp
  • Like 2
  • Agree 1
It looked all OK, so was confused when it should have worked, was busy earlier so didn't work out why or give a link in my answer (lunch now)
Lee MAc SSGET reference page is: http://lee-mac.com/ssget.html
and for very-very long text code 3 4 1 172 304 should get -all- the text considered (250 characters for each)
  (sssetfirst nil ss)
--edit
Thank you for your help! What I noticed it is indeed working with simple text bot not at all with MTEXT. I even tested only with MTEXT and no luck. Any ideea why?
If you have super long text the 3 code could fail if the contents is not within the first entry:
IMO it's much easier to select all text then remove items that don't match.
(defun c:seltxt	(/ ss)
  (if (setq ss (ssget "_X" (list '(0 . "*TEXT") (cons 410 (getvar 'ctab)))))
    (progn (foreach e (mapcar 'cadr (ssnamex ss))
	     (or (wcmatch (strcase (vla-get-textstring (vlax-ename->vla-object e))) "*DESIGNER*")
		 (ssdel e ss)
	   (sssetfirst nil ss)
But you could also use the FIND command to do the same.
  • Like 3
Thank you! Appreciate a lot the help. It is working. You guys are brilliant!
Seems to work in BricsCAD. but @ronjonp to the rescue.
Glad to help! :beer:
